Go to Post I've done enough preaching to the choir. Let's carry on changing the culture. - StevenB [more]
Unread 12-02-2009, 17:57
whitecloudhiker whitecloudhiker is offline
FRC #1561
whitecloudhiker is an unknown quantity at this point
Can't manage to calibrate Jaguars
We are working on getting our jaguars calibrated, but we can't seem to do it right. We looked in the manual and found the jaguar section with a step-by-step list of procedures to calibrate.
Following it word for word it didn't calibrate.
1) We held down the user button until the light flashed green and red
2) We moved the joystick forward to our max that we wanted (tried to make it pretty slow so that we could tell that it was working)
3) Moved the joystick backward to our max
4) Set it back to neutral
5) Light flashed green and yellow to show that we finished
I felt as though we had done it right, but nothing changed.
Just in case we were doing it wrong, we tried one other way.
We did the same thing, but instead of letting go of the user button, we held it down the whole time and let it go at the end.
We must be doing something wrong, but no one on our team can seem to figure out what.
I would greatly appreciate some input from anyone that has done this correctly.
Manually Calibrate White Balance MartinStewart Technical Discussion 2 23-01-2009 13:28
How to Auto Calibrate J30H30 Programming 13 12-03-2008 10:54
How do you manage larger assemblies? naroarr Inventor 11 15-02-2008 14:40
How do you manage code changes? ericand Programming 22 01-03-2006 03:56
How did you guys manage it? archiver 1999 1 23-06-2002 21:56
