Go to Post Whenever we loose a committed member of FRC, our entire country pays the price. - daniel_dsouza [more]
Unread 12-02-2009, 20:18
Team2339's Avatar
Team2339 Team2339 is offline
Mentor#1
AKA: Myrle McLernon
FRC #2339 (Robolopes)
Team2339 is a splendid one to beholdTeam2339 is a splendid one to beholdTeam2339 is a splendid one to beholdTeam2339 is a splendid one to beholdTeam2339 is a splendid one to beholdTeam2339 is a splendid one to beholdTeam2339 is a splendid one to behold
2009 large cooling fans
ok can someone help us out and give us some help on how to connect the large cooling fans?????????
2008 LA Regional
2009 San Diego Regional 5th Seed, 2009 Las Vegas Regional Semi-Finalist
2010 San Diego and LA
2011 Bound for same
KQ6Y
Scientia Super Omnia
Unread 12-02-2009, 20:40
richwong richwong is offline
None #1701 (Robocubs)
richwong is an unknown quantity at this point
Re: 2009 large cooling fans
Just wire them up directly to the breaker panel. Use a 20 Amp breaker and the appropriate wiring.
Unread 12-02-2009, 20:45
Team2339's Avatar
Mentor#1
AKA: Myrle McLernon
does it require any switching
or can we just let it run?
and thanks for the reply!
finally someone had some answer
2008 LA Regional
2011 Bound for same
KQ6Y
Unread 12-02-2009, 21:00
Team2339's Avatar
Mentor#1
AKA: Myrle McLernon
hello?
lol
2008 LA Regional
2011 Bound for same
KQ6Y
Unread 12-02-2009, 21:44
If the application for which you are using this fan requires operator control, you can accomplish that by using a Spike Relay. Otherwise, there are no requirements in the rule that there be any "switching."
Unread 12-02-2009, 21:50
Team2339's Avatar
Mentor#1
AKA: Myrle McLernon
thank you!
youre awesome
lets see how this turns out now
2008 LA Regional
2011 Bound for same
KQ6Y
Cooling A Room Pavan Dave Technical Discussion 32 26-05-2007 16:59
Using two Large PAPST Fans? SuperDave Electrical 9 17-02-2003 15:11
Water cooling? kc8nod Motors 12 08-02-2003 10:17
Cooling Drill Motors archiver 2001 5 23-06-2002 23:48
Air Cooling Jordan A. Technical Discussion 23 06-02-2002 21:39
