Re: programming buttons
Well, not knowing what mechanism you use makes it hard to give any help. However, I can help you with the joystick. I use the Joystick Get vi. Unbundle the buttons cluster (the trigger is button one) and wire the booleans to your throwing code, most likely some case structures.
| Programming 2 buttons for a relay | team877 | NI LabVIEW | 15 | 18-02-2011 00:18 |
| programming a motor to two buttons | solomason519 | Programming | 2 | 28-01-2009 12:37 |
| Help Programming Buttons | LordFrz | Programming | 3 | 14-02-2008 13:55 |
| Programming Extra Joystick Buttons | Inverted | Programming | 2 | 08-02-2007 11:45 |
| Programming motors with joystick buttons | TMHStitans | Programming | 5 | 21-03-2005 21:07 |
