Go to Post Patience is the key to FIRST. - Pavan Dave [more]
Unread 12-02-2009, 21:32
robself705's Avatar
robself705 robself705 is offline
Team Leader / Mechanical
AKA: Rob Self
FRC #0706 (Cyberhawks)
robself705 is a name known to allrobself705 is a name known to allrobself705 is a name known to allrobself705 is a name known to allrobself705 is a name known to allrobself705 is a name known to all
problems with multiple encoders, please help!
we're using a total of 4 encoders on our robot, 2 for steering, and 1 for a turret. but when any more than 1 encoder is defined, only the one that is defined first works. here is a sample of some code that only read one of the encoders in teleoperated mode
Encoder front(1,2);
Encoder back(3,4);
while (1)
printf("%d %d\n", front.Get(), back.Get());
front.Get gives back a value when we turn the encoder but back.get does not, we've checked the wiring a hundred times, any help would be greatly appreciated
Unread 12-02-2009, 21:52
Wylie99998 Wylie99998 is offline
FRC #0871
Wylie99998 is an unknown quantity at this point
Re: problems with multiple encoders, please help!
um well can u send ur actual code maybe ur instantiating them incorrectly. btw if u made them pointers u must use the -> operator instead of the . operator and also u have to have a line somewhere starting the counting ( ex back->Start();
Unread 12-02-2009, 22:00
dboisvert dboisvert is offline
AKA: Dan Boisvert
FRC #2405 (Divided by Zero)
dboisvert is an unknown quantity at this point
Encoder front(1,2);
Encoder back(3,4);
while (1)
printf("%d %d\n", front->Get(), back->Get());
That should do the trick
Unread 12-02-2009, 22:06
robself705's Avatar
AKA: Rob Self
we tried it with the pointers and we had the same result, one encoder worked while the other did nothing. if we didnt initiate them properly than either it wouldnt compile or both of them wouldnt run, right?
Unread 12-02-2009, 22:11
FRC #0871
hmm the fact that one is running is odd.. have u checked on a volt meter if the sensor is sending back pulses?
Unread 12-02-2009, 23:46
reversed_rocker's Avatar
reversed_rocker reversed_rocker is offline
Alumni
AKA: Ken Condon
reversed_rocker is on a distinguished road
yeah we took an oscilliscope to all of the encoders and all of them are sending back pulses. whats especially weird is that if you comment out the first encoder, the second encoder gives data back. but if you have both encoders running at the same time, only the one that's defined first will send back data
Unread 13-02-2009, 00:22
Shouldn't you be using the %f format specification instead of %d? I thought encoders returned floating point values.
Unread 13-02-2009, 00:56
Alumni
AKA: Ken Condon
thats problably true, but i dont see how that would cause only one encoder to give back values
Unread 13-02-2009, 01:00
It would cause the printf() to report the values incorrectly. If that's the only thing making you think the encoders aren't working right, the encoders might actually not be misbehaving at all.
Can anyone help with encoders Chris11246 NI LabVIEW 2 06-02-2009 15:28
Multiple Robots, Please Help Zyik Control System 3 17-02-2008 20:43
Please help me with my Camera problems! Ianuser Programming 2 10-02-2007 21:17
Need help with shaft encoders edthegeek Control System 9 23-11-2006 15:08
Problems with PID- PLEASE HELP!!! thinkpad Programming 12 10-02-2005 00:18
