Go to Post *be there or be triangle, circle, square - PVCpirate [more]
Unread 12-02-2009, 21:39
Ozeaden Ozeaden is offline
FRC #1388 (Eagle Robotics)
Ozeaden is an unknown quantity at this point
Re: pic: 1388: Gyration
Originally Posted by Eric Bareiss View Post
I'm assuming you have the gyro spinning the same direction the whole time. Correct me if I'm wrong, but shouldn't the gyro tip side to side instead of front to back? The physics of this gyro looks sideways. If the gyro is spinning to the right and you tip it forward, the force would be forward, which doesn't help with turning.
The physics do not change and as the default position of the gyro is vertical the tourque does not affect driving unless tilted...which is the point...obviously...
http://www.eaglerobotics.com/
pic: 1388 Hammertime grantman54 Extra Discussion 5 16-04-2008 12:09
pic: 1388 Presents: Lucky! BQuennell Robot Showcase 5 26-02-2007 02:12
pic: Team 1388: Finished Mike Hendricks Robot Showcase 10 22-02-2006 22:52
pic: Team 1388 Gearbox Mike Hendricks Robot Showcase 5 07-02-2005 17:26
pic: Team 1388 Teaser Mike Hendricks Extra Discussion 10 27-01-2005 10:28
