Go to Post We're 30 pounds over LOL. I probably shouldn't be lol'ing, but it is 11:52PM, I just got home from a 15 hour build session, and I find the word 'potato' funny. - ZakuAce [more]
Unread 12-02-2009, 19:17
AlbertW90 AlbertW90 is offline
Team 988 Vice President
FRC #0988 (Clark Robotics)
Team Role: Electrical
AlbertW90 is an unknown quantity at this point
Yellow Flashing Jaguar/Victor Lights
Our team has been having jaguar and victor motor problems. With both the Jaguar and Victor motors(not being used at the same time) the status lights flash yellow, for a lack of signal, while doing a tethered benchtop test. The Crio's link light flashes orange rapidly, but all other lights are working. Everything appears to be wired correctly. I have data wires going from the sidecars to the Jaguar/Victor, and the gray computer cord going from crio port 4 to the sidecar, and an ethernet cord from driver station ETH1 to the Crio's port 1. I am starting to expect that there is some sort of lurking broken part in my control system, but I am unable to tell what.
All help is greatly appreciated
- Team 988
Unread 12-02-2009, 20:04
Racer26 Racer26 is offline
Re: Yellow Flashing Jaguar/Victor Lights
This is indicitave of a robot that is not enabled.
Unread 12-02-2009, 22:51
When we flip the enable/disable dongle on the side of the drivers station, the lights on the jaguars/victors do not change to a solid unblinking yellow like they are supposed to, or change colors when the joysticks are pressed.
Unread 12-02-2009, 22:53
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
What does your Driver's Station say next to "battery" while you are experiencing these issues?
Unread 12-02-2009, 22:57
The battery reads N/A. We have not yet updated the firmware on the CRio or the Driver Station.
Unread 12-02-2009, 23:39
Are the LEDs on the ethernet ports lit? What color? Not the ones on the top of the Driver Station, but the ones on the actual sockets into which the Ethernet patch cable is plugged.
Unread 13-02-2009, 14:21
The Orange light flashes orange rapidly, and the green light is solid. (The ones on the CRio)
Unread 16-02-2009, 02:46
BurtGummer BurtGummer is offline
Electrical/Mechanical/Programming
FRC #3020
BurtGummer will become famous soon enoughBurtGummer will become famous soon enough
What is the green status light on the Digital Sidecar doing? If it is solid green, it means it has a connection to the Driver Station. If it's flashing, then simply put, it's not good. If it is flashing, you could have a networking issue.
I dealt with a problem like this for 2 days......networking is not fun.
Unread 16-02-2009, 07:49
Don't forget that you cannot update the software on one part of the system without doing the other. The DS and Crio need to be updated together.
Unread 16-02-2009, 10:16
Electrical Engineer
Rookie Year: 1995
Burt,
Please note that some flashing sequences (slow blink) are normal.
Please see this page on status light meanings.
Regards,
Mike
Mike Betts
As easy as 355/113...
Unread 16-02-2009, 11:06
Russ Beavis Russ Beavis is offline
Russ Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond repute
Also, it's not clear that teams are always wiring their RSL per the Power Distribution Diagram. The extra jumper between La and Lb is necessary. Without that jumper (and depending on whether the + output from the DSC is wired to La or Lb), your RSL may always flash.
http://www.usfirst.org/uploadedFiles...%20diargam.pdf
Russ
Jaguar Flashing Light Disable Problem Mike Yaremko FRC Control System 4 11-02-2009 14:55
Jaguar yellow blinking light after updates Team 691 Electrical 8 26-01-2009 00:14
Jaguar and Victor Flashing lights? programmr FRC Control System 24 17-12-2008 15:44
pic: Jaguar next to Victor ajlapp Extra Discussion 26 10-08-2008 17:56
Flashing Red Robot Feedback Lights zarf Programming 2 12-02-2005 16:01
