Go to Post I do want to remind people: Safety glasses, adult supervision and don't let freshmen touch the robot. ::safety:: - rtfgnow [more]
Unread 12-02-2009, 00:00
Mazin Mazin is offline
FRC #1720
Mazin is a name known to allMazin is a name known to allMazin is a name known to allMazin is a name known to allMazin is a name known to allMazin is a name known to all
Send a message via AIM to Mazin
Mazin's Last Minute Adobe Premiere exporting guide
Using Premiere? Need to get your animation in the right format? It's the same every year: You will get trapped by QuickTime.
  1. Get your animation ready for export according to Autodesk's instructions for slate, audio, etc.
  2. When you go to Export Movie, go into the export settings (on the save file dialog) and make sure you have:
    • General: File Type is QuickTime, other options should be default
    • Video: Compressor is "DV/DVCPRO - NTSC" and the frame size is 720x480, fps is 29.97, pixel aspect ratio (did you remember this when you animated?) is 0.9. Under the Compressor's "Configure..." choose Scan Mode Progressive and 4:3 aspect ratio.
    • Keyframe and Rendering: Fields should be "No Fields (Progressive Scan)"
    • Audio: Uncompressed 48kHz 15-bit sound
  3. When you go to play back your shiny new MOV is QT, you might be astonished to notice how terribly crappy it looks. Fear not. QT is in low-quality mode for some reason. Set QuickTime to high quality: In QuickTime Player, Edit > Preferences > Player Preferences > Use high quality video setting when available.
Have fun and good luck with your animation!
Unread 12-02-2009, 08:49
BuddyB309's Avatar
BuddyB309 BuddyB309 is offline
I freaking love animating!!
AKA: Peter Casey
FRC #1625 (Winnovation)
Team Role: Animator
BuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond repute
Send a message via AIM to BuddyB309
Re: Mazin's Last Minute Adobe Premiere exporting guide
wow eric, you've really been helpfull. Althought I didn't see alot of "HELP!! WE'VE JUST STARTED USING MAX TWO DAYS AGO AND HOW DO I EXPORT!!" questions this year.
A.K.A Llama
check out my latest animations Appliance Night Out, Infant Intolerable, Fishing Like a Loony Tune, VVV Roadside Assistance
Life? I have a life. It is sitting at my computer and Animating. AND DRAWING!!! WEEEEEEE!!!!
Unread 12-02-2009, 11:22
FRC #1720
Yeah, I noticed that too, and I can't help but wonder if there are simply fewer teams doing animations this year. Or people are getting better at file formats. Or ChiefDelphi is losing its touch.
Unread 12-02-2009, 18:17
MasterRobot's Avatar
MasterRobot MasterRobot is offline
<= Psychedelic Cloud....
FRC #2438 ('Iobotics)
Team Role: Animator
MasterRobot will become famous soon enoughMasterRobot will become famous soon enough
but are quicktime movies and .mov the same?
or is there something that makes them different?
Unread 12-02-2009, 18:39
FRC #1720
.MOV is the official extension for QuickTime movies.
Unread 12-02-2009, 22:15
Morgan Gillespie's Avatar
Morgan Gillespie Morgan Gillespie is offline
I haven't any bullets
AKA: NPC / Mercury Rising
FRC #0025 (Raider Robotix)
Team Role: Driver
Morgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond repute
Send a message via AIM to Morgan Gillespie
If someone wishes, I can post up a guide on how to do this for those who lack adobe premier or another capable program, to run your finished video straight out of 3DSM stock, meeting all the required guidelines. This allows teams to use any commonly available, although highly less capable video editing program.
{Windows Movie Maker... usually}
[Edit : A tad late now, I understand. It is a lot nicer to not have to run EVERYTHING through video post.]
Bristol-Myers Squibb Company
Events Competed:
-Duel on Delaware 05, 06, 07, 08 - Ramp Riot 05, 06, 07 08 - Brunswick Eruption 05, 06, 07 08 - PARC 06, 07, 08 - Monty Madness 0608 - Battle O' Baltimore 07 08 - Pascack Panda-monium - 08
__________________________________________________ _________________________
NJ 06, 07, 08 09 - UTC 07 -LV 06 - HI 08 - ATL CMP 06, 07, 08
Unread 12-02-2009, 22:42
lilwupster lilwupster is offline
AKA: Brett Van Dorn
FRC #0303
Team Role: Animator
lilwupster has a spectacular aura aboutlilwupster has a spectacular aura aboutlilwupster has a spectacular aura about
I actually really like video post (makes putting all those frames together nice and easy). Ever since I learned how to use it I do, even though I have other video editing programs.
BVD
Unread 12-02-2009, 22:59
BuddyB309's Avatar
AKA: Peter Casey
Team Role: Animator
but video post, you have no control over sound. sound plays a BIG part in animation.
A.K.A Llama
Unread 13-02-2009, 21:36
AKA: Brett Van Dorn
FRC #0303
Team Role: Animator
You do have control over sound in video post if you can use the curve editor correctly.
BVD
Unread 13-02-2009, 21:48
BuddyB309's Avatar
AKA: Peter Casey
Team Role: Animator
ooo. Thats really tough with video post though. You only have one channel for sound. sound its supposed to be layered. Sound effects, Ambient, Music, and Dialog.
A.K.A Llama
Unread 22-02-2009, 15:28
Magiciandude's Avatar
Magiciandude Magiciandude is offline
FRC #1746
Magiciandude is just really niceMagiciandude is just really niceMagiciandude is just really niceMagiciandude is just really niceMagiciandude is just really nice
Remember though...you can create your whole audio track in a separate program like audacity(free)...even if that isn't the preferred way to do it...
Sony Vegas or Adobe Premiere? Pavan Dave Chit-Chat 5 08-01-2009 18:41
Last Minute Work! Aratarin Chit-Chat 0 18-02-2007 16:08
A few last minute questions Jesse Control System 1 21-02-2004 19:31
Last-Minute changes? Iain McLeod General Forum 9 09-04-2003 02:51
LAST MINUTE Pneumatic Question archiver 2001 6 24-06-2002 01:11
