Go to Post "But from a real life standpoint, that looks like something the evil villains in a superhero movie would use to get around in" Reading the phrases "real life" and "evil villains in a superhero movie" in the same sentence makes me giggle. - Alan Anderson [more]
Unread 12-02-2009, 23:12
Re: Second Color is not being processed!
The other things I'd look at are to open up the FindTwoColor VI. Open up the diagram and probe the images. Just before the loop on the right side is an array of particle info going in. For each particle, it will extract image pieces and mask and measure particles there. Probe the area of the upper and lower and compare to the input particle area. You can also probe the extracted images to see if there is anything wrong with them.
The other suggestion about posting the images that don't work is a really good one by the way.
Greg McKaskle
Color template not loading? the_waterboy NI LabVIEW 4 23-01-2009 19:28
Compact rio not being able to use C kenethare Programming 47 10-09-2008 22:33
First CROSSING not being scored? jgannon Rules/Strategy 22 09-03-2008 11:08
EDU RC not being recognized... Caleb Fulton Programming 5 24-03-2003 09:29
