Go to Post at what point does gracious professionalism turn into cut throat competition? - aepstein [more]
Unread 12-02-2009, 23:06
Shadow_Cat's Avatar
Shadow_Cat Shadow_Cat is offline
AKA: Mae Cates
FRC #1013 (The Phoenix)
Shadow_Cat is an unknown quantity at this point
CRio Not Responding
Ok here is what is happening. Our CRio was responsive but now we can not get any code running. The battery voltage on the DS comes up as 00.00. I have no idea what happened. It is only a few days until shipment please help me!
Unread 12-02-2009, 23:12
airnate airnate is offline
FRC #0236 (Techno Ticks)
airnate is a jewel in the roughairnate is a jewel in the roughairnate is a jewel in the rough
Re: CRio Not Responding
What happens when you try to deploy code to the cRIO by running a VI?
Unread 12-02-2009, 23:13
Shadow_Cat's Avatar
AKA: Mae Cates
It loads but nothing happens.
Unread 12-02-2009, 23:15
If you just push the run button on your robotMain, what happens?
Greg McKaskle
Unread 12-02-2009, 23:20
Shadow_Cat's Avatar
AKA: Mae Cates
The code deploys and our robot will not move all the lights blink and the voltage on the driver station says 00.00.
Unread 12-02-2009, 23:29
Stuart's Avatar
Stuart Stuart is offline
#include coffee.h
FRC #1745 (P51- Mustangs)
Stuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond repute
Send a message via AIM to Stuart
We had this happen to us after labview crashed while uploading code. Reimage the cRio then reload your code. Thats what fixed it for us
Proud mentor of Team #1745 the P-51 Mustangs
If at first it doesn't work, use a hammer.
If that doesn't work, use a bigger hammer.
Unread 12-02-2009, 23:45
My suspicion is that you have a version problem between the cRIO and the WPI library.
If you launch the dashboard it will show errors occurring on the cRIO. I think it is -44085 that indicates a version problem. If this is your problem, reimage the cRIO to v11, and be sure to push the checkbox to reformat.
Greg McKaskle
Unread 13-02-2009, 08:12
Shadow_Cat's Avatar
AKA: Mae Cates
We re-imaged it twice and nothing worked.
Speed controllers not responding augzodia National Instruments LabVIEW and Data Acquisition 4 30-01-2009 01:20
Motors not responding to joysticks indubitably FRC Control System 6 08-01-2009 16:14
Camera Not Responding To Code itzrobz Programming 2 05-02-2006 12:47
grab frame not responding ahmed LabView and Data Acquisition 4 28-01-2006 10:49
STAMP II not responding to computer archiver 2000 4 23-06-2002 22:24
