Go to Post I find it quite amazing that this thread has been continuously active for more than two years. - Stephanie [more]
Unread 12-02-2009, 23:44
JeffatJITB JeffatJITB is offline
FRC #2910
JeffatJITB is an unknown quantity at this point
Re: Second Color is not being processed!
Well the settings we know are correct because if we choose to track green first, then green is found perfectly while it doesn't find pink at all.
Thanks for the replies, but we're still in trouble!
Unread 12-02-2009, 23:50
Keep in mind that angling your fabric even a small amount will cause it to reflect very different light to the camera. So tracking green works, then the flat fabric is tilted ten degrees and it disappears.
It is your robot, but I'm telling you, and more importantly, the statistical histogram is telling you that your green settings are the problem.
Greg McKaskle
Unread 13-02-2009, 00:24
FRC #2910
Thanks for all your help so far, but the color is perfect because when we want green to load first (notice how there is a check box in the left side of the VI that says "load pink first") if that is un-checked then it finds green just fine, but it doesn't show pink! Whichever color is loaded first is the only one being found.
And thanks again for all of your help.
Unread 13-02-2009, 02:35
RyanCahoon's Avatar
FRC #0766 (M-A Bears)
Also make sure that if you're creating a new image and passing it in as Image DST to Color Threshold, etc. If you don't do this, it will do in-place thresholding, which means that it will replace the source image with the filtered red/black image, so when you go to do the filtering for the second color, it won't find it. To fix this, create a new image using IMAQ Create (make sure to give it a different name) and wire the new image into the Image DST input on the first Color Threshold (to be extra safe, create another one for the second Color Threshold as well).
I haven't actually looked at the inside of the demo vision code to see what it does, so you may have already done this when converting the code, but this is a problem I've had before when writing my own vision code. Seeing a glimpse every 30 frames also sounds similar to what I've seen before.
--Ryan
FRC 766, 2015-, Mentor
Unread 13-02-2009, 07:32
Since I can't see the diagram, perhaps something else is going on too, but one more time, the measurement above show that in that picture your green was too narrow on all three values. If you do the threshold by hand using the results of the histogram, you will see that the green will not pass.
If you post a picture of the diagram, perhaps we can see if anything else looks fishy.
Greg McKaskle
Color template not loading? the_waterboy NI LabVIEW 4 23-01-2009 19:28
Compact rio not being able to use C kenethare Programming 47 10-09-2008 22:33
First CROSSING not being scored? jgannon Rules/Strategy 22 09-03-2008 11:08
EDU RC not being recognized... Caleb Fulton Programming 5 24-03-2003 09:29
