Go to Post You can build an amazing robot that is capable and beautiful on a limited budget. - Andy Baker [more]
Unread 12-02-2009, 19:54
xtreampb's Avatar
xtreampb xtreampb is offline
Lead Programmer 2642
FRC #2642 (Pitt Pirates)
xtreampb is an unknown quantity at this point
Send a message via AIM to xtreampb Send a message via Yahoo to xtreampb
"GetTrigger(KHand hand)" what???
in the joystick class, the member function GetTrigger(), how do i use this. I am using it in the following code:
if (m_FireStick->GetTrigger())
solenoid->Set(true);
solenoid->Set(false);
when i press the trigger, the code isn't executing. what am i doing wrong
Unread 12-02-2009, 19:59
pheadxdll pheadxdll is offline
AKA: Alex
FRC #1225 (Amperage Robotics)
pheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud of
Re: "GetTrigger(KHand hand)" what???
Uh... you're setting it on then off imediately. Try this:
}else{
Amperage Robotics Team 1225
Site under-going revamp. :/
Unread 12-02-2009, 22:23
xtreampb's Avatar
the code in the brackets is fine. it runs when i use if(GetRawButton(button))
It doesn't work when i use the GetTrigger(); do i need to use any paramiters because i know that in the templet or tool tip it says hand so i know that is fir the generic HID but do i need to insert anything. I dont get any build errors when I dont use paramiters.
Please ignore the poor spelling, there is a reason why i program on a computer...spell check
~xtreampb~
Pitt Pirates 2642
Unread 12-02-2009, 23:33
How do you know it runs? It looks like it won't have any noticeable effect. It turns on a solenoid output so briefly that there should be no time for a mechanical component to respond before it's turned off again.
Unread 12-02-2009, 23:51
xtreampb's Avatar
so are you saying that i need to use like a wait(0.5) before it set it to false again. I am changing it so fast because it is going to be out "plundger" and it needs to reload itself as fast as possible or else the other balls in quene will get jamed behind the launcher (especially if the person working the fire control doesn't know what he/she is doing)
~Xtreampb~
Pitt Pirates 2642
Lead Programmer
Analog inputs not "working" — I only detect "noise" keehun Programming 11 31-12-2008 19:01
Championship Event - Where the "Random" Match Sorting Really "Shines" Travis Hoffman Championship Event 57 19-04-2007 08:06
New NEMO White Papers! "Creating a Killer Packet" and "25 Ways to Sponsor" Jessica Boucher Team Organization 0 10-08-2005 10:55
"Thunderbirds" Vs. "Team America" Which one will rule the box office? Elgin Clock Chit-Chat 3 07-09-2004 19:53
how tall is the ramp when in "up" and "balanced" position??? archiver 2001 1 24-06-2002 00:54
