Go to Post Sooo....in the famous words of Douglas Adams, Don't Panic. - Conor Ryan [more]
Unread 10-02-2009, 15:07
JBotAlan's Avatar
JBotAlan JBotAlan is offline
Forever chasing the 'bot around
AKA: Jacob Rau
FRC #5263
JBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond repute
Send a message via AIM to JBotAlan Send a message via Yahoo to JBotAlan
Data logging to internal memory
This is probably going to be a stupid simple answer, but I am away from the cRIO at the moment and won't be back to it until tomorrow; bear with me.
How would I go about writing a small text file for logging purposes on the cRIO inside WindRiver? Can I just use fstream to write a file? Is there any provision inside WPILib that I should be using instead?
Jacob
Aren't signatures a bit outdated?
Unread 10-02-2009, 16:35
Redneck's Avatar
Redneck Redneck is offline
Hacker Hick
AKA: Jamie (2.0) Moran
FRC #0599 (Robodox)
Redneck is just really niceRedneck is just really niceRedneck is just really niceRedneck is just really nice
Send a message via AIM to Redneck
Re: Data logging to internal memory
You should be able to just write a file to the cRIO using a regular fstream and retrieve it later via FTP.
Which badges can you claim?
Unread 10-02-2009, 18:51
slavik262's Avatar
slavik262 slavik262 is offline
We do what we must because we can.
AKA: Matt Kline
FRC #0537 (Charger Robotics)
slavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to behold
Send a message via AIM to slavik262
I created a class that provides as a wrapper to the standard C file i/o functions. I'll post it later tonight.
Unread 10-02-2009, 19:06
JBotAlan's Avatar
AKA: Jacob Rau
FRC #5263
Whoa! I didn't know the cRIO has an FTP server! I assume it is on port 21 like a normal FTP server? I guess I'm not reading the right documents...
I would definitely be interested in having a peek; this could save me some time coding a similar structure for myself.
Thanks all,
Jacob
Unread 10-02-2009, 23:02
slavik262's Avatar
AKA: Matt Kline
I've attached my class. I need to get some sleep right now, so I apologize for not providing full documentation, but the header file is commented well enough that you should get an idea of how it works fairly easily. The only note I'd like to make is that the read and write functions take pointers to the variables you are reading/writing to. Also, you can use the generic read/write functions to write c-style strings (char arrays). For the pointer to the data, provide the name of the array, dataItemSize should be sizeof(char), and itemCount should be however many characters you want to write. I apologize for lacking full string implementation. I plan on creating a WriteString function that takes a pointer to a null-terminated string later.
I hope this helps you out.
EDIT: I just noticed I left some typedefs and a definition in the header file that I needed when I tested this in Visual C++. Feel free to remove lines 6, 11, and 12 (the _CRT_SECURE_NO_WARNINGS #define and the typedefs).
Unread 12-02-2009, 07:41
Chief Pride's Avatar
Chief Pride Chief Pride is offline
<3
AKA: James Kiefer
Chief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond repute
Would it be possible to write to a USB stick in the drivers station with something like this?
Unread 12-02-2009, 09:16
JBotAlan's Avatar
AKA: Jacob Rau
FRC #5263
I am 99.9% sure that the DS ports only will handle HID devices--joysticks and the like. It may be possible to do something like this with a custom circuit, but really I don't think it's worth it. I will just FTP into the cRIO to get the log file.
Though that idea is very cool...
Jacob
Unread 12-02-2009, 09:30
wt200999's Avatar
wt200999 wt200999 is online now
Texas Instruments
AKA: Will Toth
FRC #3005 (Robochargers)
wt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud of
Send a message via MSN to wt200999
Jacob
Well you do use a thumb drive to update the driver station, so the possibility of somthing like that getting implemented may not be far off.
Can't you just use ofstream?
Programming in LabVIEW? Try VI Snippets!
FIRST LEGO League 2004 - 2005
FRC Team 870 Student 2006 - 2009
FRC Team 3005 Mentor 2013 -
Unread 12-02-2009, 09:37
That sounds like a cool feature to add to the 2010 wishlist.
Unread 12-02-2009, 13:23
<3
AKA: James Kiefer
Well, I was thinking because the cRio already saves the images from the camera when processing, it would be cool to save them to the thumbdrive, then write a simple program to arrange the images in order and play them as a video after your match.
Unread 12-02-2009, 18:34
slavik262's Avatar
AKA: Matt Kline
Yes, I could. I just prefer the C libraries to the C++ std namespace for certain things.
Unread 12-02-2009, 23:00
wt200999's Avatar
Texas Instruments
AKA: Will Toth
If I am not mistaken I did see some functions to save as AVI in the nivision.h...
Unread 12-02-2009, 23:28
xtreampb's Avatar
xtreampb xtreampb is offline
Lead Programmer 2642
FRC #2642 (Pitt Pirates)
xtreampb is an unknown quantity at this point
Send a message via AIM to xtreampb Send a message via Yahoo to xtreampb
well how much memory does the cRIO have??? My team would be sending snapshots to our laptop so the driver could tell where he is going but we have to limit our packet size so :/
~Xtreampb~
Pitt Pirates 2642
Lead Programmer
Unread 13-02-2009, 00:04
wt200999's Avatar
Texas Instruments
AKA: Will Toth
the docs say 128MB of non-volatile memory and 64MB system memory.
Time Logging and Team Management? asian_701129 General Forum 9 14-05-2008 23:26
pic: Team Data Logging Device falconmaster Extra Discussion 8 13-03-2007 10:01
White Paper Discuss: Orologio Logging System Julia Magoolia Extra Discussion 6 20-08-2005 02:41
Logging into ChiefDelphi.com question Raven_Writer Website Design/Showcase 8 30-05-2004 11:44
