Go to Post So we can bring 6x more to the Lunar Regional than all other regionals? no fair to those not going! - BBray_T1296 [more]
Unread 12-02-2009, 19:24
Paul Rodi Paul Rodi is offline
FRC #0975
Paul Rodi is an unknown quantity at this point
old SMC valve quick question
Sorry my team is kind of confused about this. Can we use the old SMC valve (part number SY3240-5L0Z) on the 2009 robot?
Thanks
Unread 12-02-2009, 19:49
Re: old SMC valve quick question
<R71> In addition to the items included in the Kit Of Parts, pneumatic system items specifically permitted on 2009 FRC ROBOTS include the following items. All included items must be “off the shelf” pneumatic devices rated by their manufacturers for pressure of at least 125psi,
and used in their original, unaltered condition (except as required for assembly with other components).
C. Solenoid valves. All such valves must have a maximum 1/8” NPT port diameter, and a maximum Cv of 0.32 (if non-Kit Of Parts valves are used, the team will be required to provide part documentation validating that the valves meet these constraints).
Now, let's look at the allowed materials...
<R31> COTS ITEMS that are generally available may be used on the ROBOT. [...]
<R32> COTS ITEMS from ROBOTS entered in previous FIRST competitions or COTS MECHANISMS that are no longer commercially available may be used under the following conditions:
A. The item must be unmodified, and still in its original condition as delivered from the VENDOR, and
B. The item must not be a part custom made for the FIRST competition and provided in the Kit Of Parts for a previous FIRST Robotics Competition (e.g. 2006 FRC transmissions, custom-made motor couplers, custom sensor strips, 2006 IFI CMUcam II modules, etc. are not permitted), and
C. The item must satisfy ALL of the rules associated with materials/parts use for the 2009 FIRST Robotics Competition)
Does the valve violate any of the above-quoted rules? Is there another rule that you think it violates?
Unread 13-02-2009, 08:48
nevereverregret's Avatar
nevereverregret nevereverregret is offline
AKA: sammy
FRC #2869 (One Small Step)
Team Role: Student
nevereverregret will become famous soon enough
Send a message via AIM to nevereverregret
yeah apparently they are allowed we are using them as well so i hope thats correct
"How do you join.
You show up.
How do you get responsibility.
You take responsibility."
Unread 13-02-2009, 08:54
Paul,
They have to be current, available parts to be part of the COTS and pneumatic rules.
Unread 18-02-2009, 18:24
m3rc1l3ss m3rc1l3ss is offline
FRC #1178 (DURT)
m3rc1l3ss is an unknown quantity at this point
I do believe that it is legal, as I have seen the valve on the SMC site. Would anyone care to confirm?
Modification of the SMC Valve? Betty_Krocker Pneumatics 8 13-02-2008 08:03
SMC Double Action Valve. Josh Hambright Pneumatics 2 14-02-2003 10:24
SMC valve leak? inwoodraider Pneumatics 1 02-02-2003 01:04
SMC Double Solenoid Valve Assembly Dave Kempskie Pneumatics 0 29-01-2003 13:34
Single Solenoid Valve SMC Chubtoad Technical Discussion 3 20-01-2002 15:16
