Go to Post When I had "shop" back in High School they emphazied safety to the fullest extreme. I'm glad they did, I still have a full set of 7 fingers........ - Stillen [more]
Unread 10-02-2009, 08:33
Bomberofdoom's Avatar
Bomberofdoom Bomberofdoom is offline
Biggest FIRST addict in Israel
AKA: Nir Levanon
FRC #2230 (Zcharia's Angels)
Bomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond repute
Send a message via MSN to Bomberofdoom
Camera tracking at 110ms
Hi,
Following some of the calculations I made, our robot needs to be able to process an image from the camera at least every 110ms.
From what I've heard, the default settings in the Two Color Servo Camera Example, the robot processes the images once every ~200ms.
Can someone tell me how to set the properties of the camera in order to lower the process time to 110ms or less?
I'm looking for a specific (and if possible, exampled) process of doing so, but any kind of help will do.
Thanks,
TEAM 2230 ZECHARIA'S ANGELS
2009 Microsoft Israel FRC Regional Winners!
2009 Microsoft Israel FRC Regional Chairman's Award Winners!!!
2008 Microsoft Israel FRC Regional semi-finalist.
2008 Microsoft Israel FRC Regional Delphi's "Driving Tommorow's Technology" Award winner.
2008 Robot Driver
2007 GM/Technion Israel FRC Regional semi-Finalist.
2007 GM/Technion Israel FRC Regional Xerox Creativity Award winner.
2007 Robot Driver.
Unread 10-02-2009, 09:10
Re: Camera tracking at 110ms
I've done the LV timings hundreds of times. 640x480 is around 5fps, 320x240 is around 10fps, and 160x120 is around 25fps. If you decimate some, you can improve it further.
You can definitely get 110ms or better. What are your other constraints?
Greg McKaskle
Unread 10-02-2009, 09:19
TheOtherGuy's Avatar
TheOtherGuy TheOtherGuy is offline
Unregistered User
AKA: Kevin Forbes
FRC #4183 (Bit Buckets)
TheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond repute
Greg McKaskle
I was wondering about this; my team is running the LabView tracking code and the best we get with 160x120 without decimation is 12 or 13 fps. Is there some trick to increasing this speed? We have yet to try tracking without live debugging (not sure how much time is lost in the communications with the laptop).
Unread 10-02-2009, 09:21
AKA: Nir Levanon
Were those measued with or without decimating? How much does decimating help? (numbers please )
And I'm not quite sure what other kinds of constraints I might have.
2008 Robot Driver
2007 Robot Driver.
Unread 10-02-2009, 09:38
Most of the time is "lost" in keeping the LabVIEW front panels updated. Close them and you'll probably be a lot happier with the timing (assuming you have a way to see what the timing actually is).
Unread 10-02-2009, 12:00
Here is the breakdown.
Open the demo panel, but not subVI panels. The example defaults to 320x240 with 2x2 decimation and both the image mask displays on.
With those settings and a target in view I get a little above 6 fps. If I turn off the display (by turning on gimbal tracking), I get 10.5. If I turn off the mask (by hitting the button below the mask, next to the fps) I get 11.5.
If you do not get these numbers there are possibly some things on your camera that are not set correctly. The ones I know of are -- you don't have an FRC/FRC account because the camera setup utility wasn't run. This causes twice the comms setup overhead before getting an image. Connect to the camera using a web browser and log in with FRC/FRC. If it doesn't work, run the camera setup or create the account by hand.
Another camera issue is if you set the compression near 0 or near 100. The default is 30. Near 0 or 100, the camera pipeline doesn't seem to be able to keep up and you will get lower frame rate.
Another issue is if you are in a dark room. To get a decent image when there isn't much light, the camera has two choices, expose the sensor longer, or increase the gain on the sensor to amplify stuff. The default setting for Exposure Priority is None which lets the camera decide. If you think this is your issue, you can set it to Frame Rate. The images may be noisier since the sensor noise will be amplified. The other option is to move to somewhere with more light.
If none of these get you similar issues, please post so that we have a reasonable baseline.
Here are the effects of image size and decimation. Both image display and mask are turned off.
Small (160x120)
Medium (320x240)
Large (640x480)
These are all taken with the panel open and with the servos running. Clearly you may have more I/O running than this, and if there is no delay or too small a delay, you could clearly have little CPU left to do vision.
Greg McKaskle
Greg McKaskle
Unread 11-02-2009, 06:37
AKA: Nir Levanon
Porbably last question,
These FPS represent the amount of pictures taken and proccessed per second, right?
2008 Robot Driver
2007 Robot Driver.
Unread 11-02-2009, 09:24
Yes. They are the value in the fps indicator and represent completed image processing loops per second. 1000/fps will give ms per image.
By the way, I'd like to know what your issue was.
Greg McKaskle
Unread 12-02-2009, 00:15
AKA: Nir Levanon
Wasn't an issue, it was more of a requirment from the cRio's and camera's capabilities in order to get a "panromaic scan" of the field , in whic the camera moves from right to left (0-170) at full speed (servo's max speed is 0.4s). From calculations of angles that the camera sees, where the camera is positioned, pixel area of a target from specific distance and more, the maximum process speed I need from my system is ~110ms. It's about 80-90ms if I include max-acceleration of robots and trailers on the field and when they're the closest to us
2008 Robot Driver
2007 Robot Driver.
Unread 12-02-2009, 00:58
Loubear's Avatar
Loubear Loubear is offline
AKA: YLou
FRC #0075 (RoboRaiders)
Loubear will become famous soon enoughLoubear will become famous soon enough
Why are you scanning the entire panorama of the field? If you know where the robot's starting position, you could always just turn the camera before going onto the field to orient it in the right direction...
Unread 12-02-2009, 14:27
AKA: Nir Levanon
and once you're done following one target (say, it's too full of empty cell's to be a potentioal target), won't you want to find the other targets?
2008 Robot Driver
2007 Robot Driver.
Unread 12-02-2009, 17:06
Loubear's Avatar
AKA: YLou
True, but you can only focus on one target at a time anyways, so why not save yourself some processing time by locking on, following that target, and switching targets only once you score (and still have time).
Unread 13-02-2009, 11:35
AKA: Nir Levanon
First target in view while doing Panoramic scan gets locked. We'll put a "Search first Left" and "Search first Right" for more driver control on where the camera should search.
2008 Robot Driver
2007 Robot Driver.
Camera Tracking Tanner NI LabVIEW 5 01-02-2009 11:28
Camera locked in "tracking", but not tracking geeknerd99 Programming 1 18-02-2007 22:47
camera tracking geekofband007 Programming 15 15-02-2007 23:50
Camera tracking problem Windward Programming 2 15-01-2007 17:59
Camera Tracking Problem cprogrammer Programming 1 18-02-2005 15:00
