Go to Post Eliminate the scavenger hunt, stop updating the software every two seconds, and make sure your examples and tutorials work. That will help a majority of the people I feel. - sircedric4 [more]
Unread 13-02-2009, 12:10
DarKCroNo's Avatar
DarKCroNo DarKCroNo is offline
FRC #2670
DarKCroNo is an unknown quantity at this point
wiring rotary limit switch?
How would we wire the limit switch?, when we open it there are 4 terminals to connect to.
Unread 13-02-2009, 13:09
Re: wiring rotary limit switch?
The four terminals are labeled. The upper two are Normally Open, meaning they will be closed when the switch is activated. The lower two are Normally Closed, meaning they will open when the switch is activated.
Unread 13-02-2009, 13:52
DarKCroNo's Avatar
FRC #2670
Is there apoint of having 2 Normally Open? wouldn't it work with just using 1 normal opena nd one normally closed? or maybe even just using one of the terminals?
Unread 13-02-2009, 14:05
You get two connections, one on each side of the switch. How would you manage to use a switch that had only a terminal for a single wire?
Unread 13-02-2009, 14:49
DarKCroNo's Avatar
FRC #2670
LOl alright thanks!
Unread 13-02-2009, 14:55
Dark,
There are certain designs that want two independent switches. Usually these designs take advantage of a timing difference between the contacts. Commonly known as make before break or make after break. This device also has replacable switch modules as listed on a few sites where it is available.
limit switch solomason519 Programming 9 09-02-2010 08:50
Using a limit switch to limit motion ManicMechanic Programming 16 20-12-2007 00:54
limit switch wedellm Electrical 4 16-02-2007 13:01
Need Help Wiring Micro Switch/Limiting Switch Windward Electrical 2 07-02-2006 18:26
