Go to Post The GDC probably took bets on how many posts they could get off of a random CAD render, and bonus points for how many people go insane from thinking about it! :yikes: - gallo26 [more]
Unread 13-02-2009, 13:12
Mr.Macdonald Mr.Macdonald is offline
FRC #2272
Mr.Macdonald is an unknown quantity at this point
Labview clustering clusters
I can't figure out how to cluster clusters? see attachment
I want to pass a cluster of all the clusters in the cluster constant
Unread 13-02-2009, 13:33
Russ Beavis Russ Beavis is offline
Russ Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond repute
Re: Labview clustering clusters
On your VI's front panel, create a cluster and then select and drag your other clusters into it. You can nest as many clusters as you'd like.
Russ
Unread 13-02-2009, 13:58
FRC #2272
Can you provide example code
Unread 13-02-2009, 14:05
Here you go.
Russ
Unread 13-02-2009, 14:14
FRC #2272
I am trying to write a function that takes a cluster as input, manipulates said cluster according to other inputs and outputs it in the same form as the original cluster
See Ascii Art
             ->Small cluster -- ... --
cluster -->                              --->  --> Modified Original Cluster
             -> Other Small cluster -- ... --
... are the manipulating parts
Unread 13-02-2009, 14:47
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Then you are going to use the bundle and unbundle cluster commands.
Unbundle the clusters. Do whatever you need to do with them. Then rebundle them back into a single cluster.
Unread 13-02-2009, 15:07
FRC #2272
Did you see my code, thats exactly what I did but It doesn't work
Unread 13-02-2009, 15:40
I apologize for the following:
Originally Posted by Xzibit
SUP DAWG, WE HEARD YOU LIKE LabVIEW SO WE PUT CLUSTERS IN YO CLUSTERS SO YOU CAN UNBUNDLE CLUSTERS WHILE YOU UNBUNDLE CLUSTERS.
Unread 13-02-2009, 16:55
FRC #2272
please provide an example of unbundling a bundle, modifying its components and rebundleing
Unread 13-02-2009, 17:03
Try this.
Russ
Unread 13-02-2009, 17:06
Oh... and if you want your VI to output the new cluster, you'll need to keep an output cluster and wire it out (see new attached).
Russ
Clustering in Labview Mr.Macdonald Programming 14 11-02-2009 19:34
Labview 8.5 vs. FRC Labview 8.5 pyr0b0y NI LabVIEW 0 01-02-2009 22:20
LabVIEW vs C/C++ 3DWolf Programming 11 05-12-2008 09:14
Linux Clusters Akash Rastogi Programming 5 13-12-2007 15:49
Labview Phreakuency LabView and Data Acquisition 6 14-01-2006 01:14
