Go to Post Another year, another picture of a Tytus injury. - Andy Baker [more]
Unread 13-02-2009, 14:53
dnrobotics11 dnrobotics11 is offline
FRC #2589
dnrobotics11 is an unknown quantity at this point
Limit Switch Code
What is the code for initializing and returning the value of a limit switch in the WindRiver language?
Would the code be the same for a jumper switch (used for immediate feedback depending on the alliance)?
Thank you very much.
Unread 13-02-2009, 15:05
Re: Limit Switch Code
Switches are switches. Just make a DigitalIn object and use its Get() method.
Unread 13-02-2009, 16:22
FRC #2589
thanks a lot
limit switch solomason519 Programming 9 09-02-2010 08:50
Using a limit switch to limit motion ManicMechanic Programming 16 20-12-2007 00:54
limit switch wedellm Electrical 4 16-02-2007 13:01
sample limit switch code??? tml240 Programming 5 17-02-2004 17:13
