Go to Post Everyone here inspires each other and helps them out. That's why FIRST is amazing. - tiffany34990 [more]
Unread 13-02-2009, 15:31
dboisvert dboisvert is offline
AKA: Dan Boisvert
FRC #2405 (Divided by Zero)
dboisvert is an unknown quantity at this point
Encoder Code
Includes the Encoder Header Files
#include "Encoder.h"
Declared the Encoder Variables
	// Declare Encoder Variables for Input
	Encoder *encoderMotor1;
	Encoder *encoderMotor2;
We plugged the into Digital Inputs 3,4 & 5,6
		// Encoders
		encoderMotor1 = new Encoder(3,4);
		encoderMotor2 = new Encoder(5,6);
Created a function in the Initialize Area to start the encoders
	void EncoderInit(void) {
		encoderMotor1.Start();
		encoderMotor2.Start();
Lastly we decided to use the print function to get the encoder values in the debug console
		// Encoder printf
		printf("%d %d\n", encoderMotor1->Get(), encoderMotor2->Get());
We receive errors on the lines encoderMotor1.Start(); & encoderMotor2.Start();
Error: Request for member 'Start' in '((BuiltinDefaultCode*)this)->BuiltinDefaultCode::encoderMotor1', which is of non-class type 'Encoder*'
Error: Request for member 'Start' in '((BuiltinDefaultCode*)this)->BuiltinDefaultCode::encoderMotor2', which is of non-class type 'Encoder*'
Any help would be much appreciated... I probably just need another pair of eyes on the code.
Unread 13-02-2009, 15:40
Re: Encoder Code
Originally Posted by dboisvert View Post
		// Encoders
Your encoderMotorN variables are pointers to Encoder objects. The C++ "dot" syntax is used with objects themselves; use the "->" syntax instead when working with object pointers, like this:
		encoderMotor1->Start();
		encoderMotor2->Start();
Doesn't the Get() method return a float? The %d format specifier in your printf() is probably going to be an issue.
Unread 13-02-2009, 15:50
AKA: Dan Boisvert
Re: Encoder Code
Thanks that fixed the build error.
So what would you suggest for a print format?
Also that didnt get me any feedback from the encoders
Unread 13-02-2009, 15:59
MattD's Avatar
MattD MattD is offline
AKA: Matthew Douglas
FRC #0228 (GUS Robotics)
MattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to behold
Send a message via AIM to MattD
Re: Encoder Code
Encoder::Get() returns an int that represents the count, automatically adjusted based on the decoding type (1x, 2x, or 4x). Encoder::GetDistance(), however, returns a double, which is the count scaled by the factor set with Encoder::SetDistancePerPulse().
Are you calling your EncoderInit() function anywhere?
GUS Robotics Team 228
2010 WPI Engineering Inspiration Award
2010 WPI Regional Champions (Thanks 230 & 20!)
2010 CT VEX Champions
2010 CT VEX Innovate Award
2009 QCC VEX Champions
2009 CT Motorola Quality Award
2007 CT J&J Sportsmanship Award
2006 CT Best Website Award
Unread 13-02-2009, 16:34
AKA: Dan Boisvert
Re: Encoder Code
Not that I know of, that is all of our code as of right now.
How do I call it? (again I am a novice C++ user)
#include "WPILib.h"
#include "vxWorks.h"
#include "DigitalInput.h"
#include "Resource.h"
#include "Utility.h"
#include "WPIStatus.h"
#include "Relay.h"
#include "DigitalModule.h"
#include "stdio.h"
#include <math.h>
#include "Accelerometer.h"
#include "timers.h"
//int delay(int ticks);
class BuiltinDefaultCode : public IterativeRobot
	// Declare variable for the robot drive system
	RobotDrive *m_robotDrive;		// robot will use PWM 1-2 for drive motors
	RobotDrive *m_Shooter;			// Robot Shoots with PWM 3-4
	RobotDrive *m_Lift;				// Robot will use PWM 5 & 6 for the Lift Motors
	// Declare Accelerometer
	//Accelerometer *accl;
	// Declare FlipperDoor Variable
	Relay *flipperdoor; // Flipperdoor
	// Declare GearTooth
	DigitalInput *flipperdoorright;
	DigitalInput *flipperdoorleft;
	// Declare Gyro
	Gyro* gyro;
	// Declare a variable to use to access the driver station object
	DriverStation *m_ds;						// driver station object
	UINT32 m_priorPacketNumber;					// keep track of the most recent packet number from the DS
	UINT8 m_dsPacketsReceivedInCurrentSecond;	// keep track of the ds packets received in the current second
	// Declare variables for the two joysticks being used
	Joystick *m_rightStick;			// joystick 1 (arcade stick or right tank stick)
	Joystick *m_leftStick;			// joystick 2 (tank left stick)
	static const int NUM_JOYSTICK_BUTTONS = 16;
	bool m_rightStickButtonState[(NUM_JOYSTICK_BUTTONS+1)];
	bool m_leftStickButtonState[(NUM_JOYSTICK_BUTTONS+1)];
	// Declare variables for each of the eight solenoid outputs
	static const int NUM_SOLENOIDS = 8;
	Solenoid *m_solenoids[(NUM_SOLENOIDS+1)];
	enum {							// drive mode selection
		UNINITIALIZED_DRIVE = 0,
		ARCADE_DRIVE = 1,
		TANK_DRIVE = 2
	} m_driveMode;
	// Local variables to count the number of periodic loops performed
	UINT32 m_autoPeriodicLoops;
	UINT32 m_disabledPeriodicLoops;
	UINT32 m_telePeriodicLoops;
public:
 * Constructor for this "BuiltinDefaultCode" Class.
 * The constructor creates all of the objects used for the different inputs and outputs of
 * the robot.  Essentially, the constructor defines the input/output mapping for the robot,
 * providing named objects for each of the robot interfaces.
	BuiltinDefaultCode(void)	{
		printf("BuiltinDefaultCode Constructor Started\r");
		// Create a robot using standard right/left robot drive on PWMS 1, 2, 3, and #4
		m_robotDrive = new RobotDrive(1,2);
		m_Shooter = new RobotDrive(3,4);
		m_Lift = new RobotDrive(5,6);
		// Encoders
		// Accelerometer
		//accl = new Accelerometer(7,8);
		// Flipper Door
		flipperdoor = new Relay(1);
		flipperdoorleft = new DigitalInput(1);
		flipperdoorright = new DigitalInput(2);
		// Acquire the Driver Station object
		m_ds = DriverStation::GetInstance();
		m_priorPacketNumber = 0;
		m_dsPacketsReceivedInCurrentSecond = 0;
		// Define joysticks being used at USB port #1 and USB port #2 on the Drivers Station
		m_rightStick = new Joystick(1);
		m_leftStick = new Joystick(2);
		// Iterate over all the buttons on each joystick, setting state to false for each
		UINT8 buttonNum = 1;						// start counting buttons at button 1
		for (buttonNum = 1; buttonNum <= NUM_JOYSTICK_BUTTONS; buttonNum++) {
			m_rightStickButtonState[buttonNum] = false;
			m_leftStickButtonState[buttonNum] = false;
		// Iterate over all the solenoids on the robot, constructing each in turn
		UINT8 solenoidNum = 1;						// start counting solenoids at solenoid 1
		for (solenoidNum = 1; solenoidNum <= NUM_SOLENOIDS; solenoidNum++) {
			m_solenoids[solenoidNum] = new Solenoid(solenoidNum);
		// Set drive mode to uninitialized
		m_driveMode = UNINITIALIZED_DRIVE;
		// Initialize counters to record the number of loops completed in autonomous and teleop modes
		m_autoPeriodicLoops = 0;
		m_disabledPeriodicLoops = 0;
		m_telePeriodicLoops = 0;
		printf("BuiltinDefaultCode Constructor Completed\n");
	/********************************** Init Routines *************************************/
	void RobotInit(void) {
		printf("RobotInit() completed.\r");
	void DisabledInit(void) {
		m_disabledPeriodicLoops = 0;			// Reset the loop counter for disabled mode
		ClearSolenoidLEDsKITT();
		// Move the cursor down a few, since we'll move it back up in periodic.
		printf("\x1b[2B");
	void AutonomousInit(void) {
		m_autoPeriodicLoops = 0;				// Reset the loop counter for autonomous mode
	void TeleopInit(void) {
		m_telePeriodicLoops = 0;				// Reset the loop counter for teleop mode
		m_dsPacketsReceivedInCurrentSecond = 0;	// Reset the number of dsPackets in current second
		m_driveMode = UNINITIALIZED_DRIVE;		// Set drive mode to uninitialized
	/********************************** Periodic Routines *************************************/
	void DisabledPeriodic(void)  {
		static INT32 printSec = (INT32)GetClock() + 1;
		static const INT32 startSec = (INT32)GetClock();
		// feed the user watchdog at every period when disabled
		GetWatchdog().Feed();
		// increment the number of disabled periodic loops completed
		m_disabledPeriodicLoops++;
		// while disabled, printout the duration of current disabled mode in seconds
		if (GetClock() > printSec) {
			// Move the cursor back to the previous line and clear it.
			printf("\x1b[1A\x1b[2K");
			printf("Disabled seconds: %d\r\n", printSec - startSec);
			printSec++;
	void AutonomousPeriodic(void) {
		// feed the user watchdog at every period when in autonomous
		m_autoPeriodicLoops++;
		// generate KITT-style LED display on the solenoids
		SolenoidLEDsKITT( m_autoPeriodicLoops );
		/* the below code (if uncommented) would drive the robot forward at half speed
		 * for two seconds.  This code is provided as an example of how to drive the
		 * robot in autonomous mode, but is not enabled in the default code in order
		 * to prevent an unsuspecting team from having their robot drive autonomously!
		/* below code commented out for safety
		if (m_autoPeriodicLoops == 1) {
			// When on the first periodic loop in autonomous mode, start driving forwards at half speed
			m_robotDrive->Drive(0.5, 0.0);			// drive forwards at half speed
		if (m_autoPeriodicLoops == (2 * GetLoopsPerSec())) {
			// After 2 seconds, stop the robot
			m_robotDrive->Drive(0.0, 0.0);			// stop robot
	void TeleopPeriodic(void) {
		// increment the number of teleop periodic loops completed
		m_telePeriodicLoops++;
		// Encoder printf
		// Accelerometer printf
		//printf("Accelerometer\n", accl->GetAcceleration());
		 * No longer needed since periodic loops are now synchronized with incoming packets.
		if (m_ds->GetPacketNumber() != m_priorPacketNumber) {
			 * Code placed in here will be called only when a new packet of information
			 * has been received by the Driver Station.  Any code which needs new information
			 * from the DS should go in here
			m_dsPacketsReceivedInCurrentSecond++;					// increment DS packets received
			// put Driver Station-dependent code here
			// Demonstrate the use of the Joystick buttons
			DemonstrateJoystickButtons(m_rightStick, m_rightStickButtonState, "Right Stick", &m_solenoids[1]);
			DemonstrateJoystickButtons(m_leftStick, m_leftStickButtonState, "Left Stick ", &m_solenoids[5]);
			// determine if tank or arcade mode, based upon position of "Z" wheel on kit joystick
				m_robotDrive->ArcadeDrive(m_rightStick);			// drive with arcade style (use right stick)
				if (m_driveMode != ARCADE_DRIVE) {
					// if newly entered arcade drive, print out a message
					printf("Arcade Drive\n");
					m_driveMode = ARCADE_DRIVE;
			// If you press Button 4 the relay goes forward
			if (m_leftStick->GetRawButton(5) == 1 && flipperdoorright->Get() == 0 ) {
				flipperdoor->Set(Relay::kForward);
				//delay(10);
			} else if (m_leftStick->GetRawButton(4) == 1 && flipperdoorleft->Get() == 0 ){
				flipperdoor->Set(Relay::kReverse);
				//delay(10);
			else{
				flipperdoor->Set(Relay::kOff);
			// If you press button 3 the joystick controls the lift instead of the shooter
			if (m_leftStick->GetRawButton(3) == 1) {
				m_Lift->ArcadeDrive(m_leftStick);
			} else {
				m_Shooter->ArcadeDrive(m_leftStick);
		}  // if (m_ds->GetPacketNumber()...
	} // TeleopPeriodic(void)
/********************************** Continuous Routines *************************************/
	 * These routines are not used in this demonstration robot
	void DisabledContinuous(void) {
	void AutonomousContinuous(void)	{
	void TeleopContinuous(void) {
/********************************** Miscellaneous Routines *************************************/
	 * Clear KITT-style LED display on the solenoids
	 * Clear the solenoid LEDs used for a KITT-style LED display.
	void ClearSolenoidLEDsKITT() {
		// Iterate over all the solenoids on the robot, clearing each in turn
			m_solenoids[solenoidNum]->Set(false);
	 * Generate KITT-style LED display on the solenoids
	 * This method expects to be called during each periodic loop, with the argument being the
	 * loop number for the current loop.
	 * The goal here is to generate a KITT-style LED display.  (See http://en.wikipedia.org/wiki/KITT )
	 * However, since the solenoid module has two scan bars, we can have ours go in opposite directions!
	 * The scan bar is written to have a period of one second with six different positions.
	void SolenoidLEDsKITT(UINT32 numloops) {
		unsigned int const NUM_KITT_POSITIONS = 6;
		UINT16 numloop_within_second = numloops % (UINT32)GetLoopsPerSec();
		if (numloop_within_second == 0) {
			// position 1; solenoids 1 and 8 on
			m_solenoids[1]->Set(true);  m_solenoids[8]->Set(true);
			m_solenoids[2]->Set(false); m_solenoids[7]->Set(false);
		} else if (numloop_within_second == ((UINT32)GetLoopsPerSec() / NUM_KITT_POSITIONS)) {
			// position 2; solenoids 2 and 7 on
			m_solenoids[2]->Set(true);  m_solenoids[7]->Set(true);
			m_solenoids[1]->Set(false); m_solenoids[8]->Set(false);
		} else if (numloop_within_second == ((UINT32)GetLoopsPerSec() * 2 / NUM_KITT_POSITIONS)) {
			// position 3; solenoids 3 and 6 on
			m_solenoids[3]->Set(true);  m_solenoids[6]->Set(true);
		} else if (numloop_within_second == ((UINT32)GetLoopsPerSec() * 3 / NUM_KITT_POSITIONS)) {
			// position 4; solenoids 4 and 5 on
			m_solenoids[4]->Set(true);  m_solenoids[5]->Set(true);
			m_solenoids[3]->Set(false); m_solenoids[6]->Set(false);
		} else if (numloop_within_second == ((UINT32)GetLoopsPerSec() * 4 / NUM_KITT_POSITIONS)) {
			// position 5; solenoids 3 and 6 on
			m_solenoids[4]->Set(false); m_solenoids[5]->Set(false);
		} else if (numloop_within_second == ((UINT32)GetLoopsPerSec() * 5 / NUM_KITT_POSITIONS)) {
			// position 6; solenoids 2 and 7 on
	 * Demonstrate handling of joystick buttons
	 * This method expects to be called during each periodic loop, providing the following
	 * capabilities:
	 * - Print out a message when a button is initially pressed
	 * - Solenoid LEDs light up according to joystick buttons:
	 *   - When no buttons pressed, clear the solenoid LEDs
	 *   - When only one button is pressed, show the button number (in binary) via the solenoid LEDs
	 *   - When more than one button is pressed, show "15" (in binary) via the solenoid LEDs
	void DemonstrateJoystickButtons(Joystick *currStick,
									bool *buttonPreviouslyPressed,
									const char *stickString,
									Solenoid *solenoids[]) {
		bool outputGenerated = false;		// flag for whether or not output is generated for a button
		INT8 numOfButtonPressed = 0;		// 0 if no buttons pressed, -1 if multiple buttons pressed
		/* Iterate over all the buttons on the joystick, checking to see if each is pressed
		 * If a button is pressed, check to see if it is newly pressed; if so, print out a
		 * message on the console
			if (currStick->GetRawButton(buttonNum)) {
				// the current button is pressed, now act accordingly...
				if (!buttonPreviouslyPressed[buttonNum]) {
					// button newly pressed; print out a message
					if (!outputGenerated) {
						// print out a heading if no other button pressed this cycle
						outputGenerated = true;
						printf("%s button pressed:", stickString);
					printf(" %d", buttonNum);
				// remember that this button is pressed for the next iteration
				buttonPreviouslyPressed[buttonNum] = true;
				// set numOfButtonPressed appropriately
				if (numOfButtonPressed == 0) {
					// no button pressed yet this time through, set the number correctly
					numOfButtonPressed = buttonNum;
				} else {
					// another button (or buttons) must have already been pressed, set appropriately
					numOfButtonPressed = -1;
			} else {
				buttonPreviouslyPressed[buttonNum] = false;
		// after iterating through all the buttons, add a newline to output if needed
		if (outputGenerated) {
			printf("\n");
		if (numOfButtonPressed == -1) {
			// multiple buttons were pressed, display as if button 15 was pressed
			DisplayBinaryNumberOnSolenoidLEDs(15, solenoids);
		} else {
			// display the number of the button pressed on the solenoids;
			// note that if no button was pressed (0), the solenoid display will be cleared (set to 0)
			DisplayBinaryNumberOnSolenoidLEDs(numOfButtonPressed, solenoids);
	 * Display a given four-bit value in binary on the given solenoid LEDs
	void DisplayBinaryNumberOnSolenoidLEDs(UINT8 displayNumber, Solenoid *solenoids[]) {
		if (displayNumber > 15) {
			// if the number to display is larger than can be displayed in 4 LEDs, display 0 instead
			displayNumber = 0;
		solenoids[3]->Set( (displayNumber & 1) != 0);
		solenoids[2]->Set( (displayNumber & 2) != 0);
		solenoids[1]->Set( (displayNumber & 4) != 0);
		solenoids[0]->Set( (displayNumber & 8) != 0);
START_ROBOT_CLASS(BuiltinDefaultCode);
Unread 13-02-2009, 17:32
MattD's Avatar
Re: Encoder Code
Before you can start reading counts from the encoders, you have to call Start() on them first. It looks like you've defined a function that does this for both of your encoders, but that function is never being called. You should call your EncoderInit() function wherever you'd like to start taking measurements, perhaps in RobotInit() or in your constructor.
void RobotInit()
   // .. Existing initialization code..
   EncoderInit();
Unread 13-02-2009, 17:42
AKA: Dan Boisvert
Re: Encoder Code
That makes a lot more sense and should work. I will post my results tomorrow morning when I have access to the robot.
Thanks a bunch!
Unread 13-02-2009, 18:05
AKA: Dan Boisvert
Re: Encoder Code
I was wondering about a few lines of code.
		printf("Encoder Motor 1: %E\n", encoderMotor1->Get());
		printf("Encoder Motor 2: %E\n", encoderMotor2->Get());
		printf("EM1 Distance: %e\n", encoderMotor1->GetDistance());
The first two lines providing the warning
warning: double format, different type arg (arg 2)
I was wondering if this would affect the data at all
Note - I also tried lowercase f instead of capital E
Unread 14-02-2009, 22:58
Jared Russell's Avatar
Taking a year (mostly) off
Re: Encoder Code
This is because the Encoder::Get() method returns an INT32 (an int), while the %E printf() token indicates a double.
Try:
printf("Encoder Motor 1: %d\n", encoderMotor1->Get());
printf("Encoder Motor 2: %d\n", encoderMotor2->Get());
Unread 14-02-2009, 23:04
AKA: Dan Boisvert
Re: Encoder Code
That did the trick. Thanks a bunch!
Unread 20-01-2011, 17:52
krudeboy51's Avatar
krudeboy51 krudeboy51 is offline
Only Programmer
AKA: kory
FRC #0369 (369)
krudeboy51 is a glorious beacon of lightkrudeboy51 is a glorious beacon of lightkrudeboy51 is a glorious beacon of lightkrudeboy51 is a glorious beacon of lightkrudeboy51 is a glorious beacon of light
Send a message via AIM to krudeboy51
Re: Encoder Code
So where exactly on the DS does the encoder values show up?
Unread 20-01-2011, 18:57
davidalln's Avatar
davidalln davidalln is offline
World's Worst Coder
AKA: David Allen
FRC #2415 (The Westminster Wiredcats)
davidalln is on a distinguished road
Send a message via AIM to davidalln
Re: Encoder Code
It doesn't automatically. When you printf(), it outputs to the target console. You can either read this using the NetConsole tool (if you've set up your cRIO to send stuff to the NetConsole, the option is in the formatting tool), or by right clicking your connection in Windriver, going to Target Tools -> Target Console (not positive this is the exact option, I don't have Windriver open, but its something similar).
SANTOSH ANDREW DECKER RICK WYNNIE SEAN DEREK MATT
(alamo (semis), p'tree (CHAMPS!), nc (CHAMPS!), newton (quarters))
Best four years of my life. Thanks to everyone who made it happen.
Encoder Code Kevin Watson Programming 47 18-02-2008 12:56
Gear encoder code Demothesis Programming 8 20-07-2007 17:15
Vex Encoder Code CircularLogic FIRST Tech Challenge 7 09-08-2006 22:12
Combining camera + encoder code kiettyyyy Programming 5 13-04-2006 09:39
Issues with encoder code jgannon Programming 7 26-03-2006 15:12
