Go to Post I have no defined complaints, and I have no solution. I simply have mixed feelings. - Andrew Blair [more]
Unread 13-02-2009, 16:30
z2daj z2daj is offline
FRC #2836 (Team Beta)
z2daj is an unknown quantity at this point
Send a message via AIM to z2daj
Inputs on Driver Station
I've been trying to work this out for a few days now. How do we get digital/analog inputs from the driver station in C++? We're going to use a rotary encoder as a knob to have a fine adjustment with our turret. Any ideas? A quick response would be greatly appreciated
There is nothing to fear, but fear itself
Unread 13-02-2009, 17:25
Redneck's Avatar
Redneck Redneck is offline
Hacker Hick
AKA: Jamie (2.0) Moran
FRC #0599 (Robodox)
Redneck is just really niceRedneck is just really niceRedneck is just really niceRedneck is just really nice
Send a message via AIM to Redneck
Re: Inputs on Driver Station
The DriverStation class has GetAnalogIn() and GetDigitalIn() methods for that.
Complete reference available here
Which badges can you claim?
Unread 13-02-2009, 17:45
thanks for your quick repsonse, however we're a rookie team so when i took a look at that along with the other programmer, we both got headaches could you explain just a little?
Unread 13-02-2009, 19:59
Redneck's Avatar
Hacker Hick
FRC #0599 (Robodox)
Sure. In your code, you'll need to have something like this:
class MyRobot : public SimpleRobot{
    // Member variables (DigitalInputs, Joysticks, Jaguars, etc)
    DriverStation *ds;
    // Default constructor
    MyRobot(){
         // Initializations for all your other variables
         ds = DriverStation::GetInstance();
    void OperatorControl(){
         float a_variable;
         while ( IsOperatorControl() ){
               OtherFunctionCalls();
               a_variable = ds->GetAnalogIn(1); // returns value of whatever's connected to analog input 1 of the DS
               if(ds->GetDigitalIn(2)) { // checks state of DS digital input 2
                    DoSomething();
               else{
                    DoSomethingElse();
Does that clear things up a bit?
It'll be slightly different if you're using the IterativeRobot template instead of SimpleRobot, but the Driver Station function calls are the same.
Unread 13-02-2009, 20:12
Sentient's Avatar
Sentient Sentient is offline
FRC #0639 (Code Red)
Sentient is on a distinguished road
Rather than using an encoder, it may be easier to just hook up a POT to in analog IO pins and use driverStation->GetAnalogIn(#) and turn this into a rotational value. The reason this may be easier is that to get a rotational value or really anything useful from the encoder in the driver station would take a bit of work. There is no Encoder class that can interface with the driver station as is.
Unread 13-02-2009, 20:13
oh wow, ha. thank you so much! yea that clears things up a lot now here's one more question... how would we get rotary encoders working? we bought ours from digikey m/n EM14 - 14 ; since we were missing a key component to the ones supplied to us in the KoP. we're not too sure on the coding for the encoders, everything we have tried has ended with Red Error Messages of Demise (REMoD) and any console outputs are 0. this is what we have for our code:
#include "Encoder.h"
class RobotDemo : public SimpleRobot
		Encoder rotary;
public:
	RobotDemo(void):
		rotary(1, 2)
void Autonomous(void)
		gyro.Reset();
		int display;
		while (IsAutonomous())
			float anything;
			while(argument)
				GetWatchdog().SetEnabled(false);
				rotary = new Encoder(1,2);
				Wait(0.004);
				display = rotary;
				printf (" %d \n ", display);
void OperatorControl(void)
any ideas?
Unread 13-02-2009, 20:16
that would work great, however we have to rotate all the way around for our turret
Unread 15-02-2009, 01:57
Redneck's Avatar
Hacker Hick
FRC #0599 (Robodox)
Originally Posted by z2daj View Post
		Encoder rotary;
public:
	RobotDemo(void):
		rotary(1, 2)
		gyro.Reset();
		int display;
			float anything;
			while(argument)
				Wait(0.004);
				display = rotary;
any ideas?
Ok, couple of things to fix here:
1)You need to add a call to the Encoder class's Start() function.
2)You're creating a new Encoder in the autonomous. You don't need that, you already created it at the constructor.
Here's how things should look:
		Encoder rotary;
public:
	RobotDemo(void):
		rotary(1, 2)
		gyro.Reset();
                rotary.Start();
		int display;
			float anything;
			while(argument)
				Wait(0.004);
				display = rotary.Get();
EDIT: Also, keep in mind that this only works for digital encoders connected to one of the cRIO's digital sidecars. If what you want is a knob on the driver station, then as Sentient mentioned previously you'll need to get a potentiometer and use the DriverStation GetAnalogIn() function.
Unread 16-02-2009, 04:12
ok, you're in California? it's 4:11AM here, we've been at our workshop for over 50 hours straight and you sir, just saved us. we give you a round of applause, and we seriously did. our programming team of two people literall stopped what we were doing and clapped. thank you so much for everything, if there is ever anything you need, we owe you big time. thanks again. seriously, thank you so much
using digital inputs from the driver station SL8 NI LabVIEW 2 04-02-2009 15:53
Trouble Reading Drivers Station Digital Inputs Mike Mahar C/C++ 3 03-02-2009 23:37
Programming Digital Inputs from Driver Station spooncwru Programming 8 01-02-2009 13:14
LabVIEW - Analog inputs from driver station lag? RedOctober45 NI LabVIEW 1 30-01-2009 10:39
Using driver station digital inputs Japper FRC Control System 6 19-01-2009 20:01
