Go to Post We don't require innovation; we simply encourage it. - Tristan Lall [more]
Unread 13-02-2009, 20:12
PWHSrobotics PWHSrobotics is offline
PWHSrobotics is an unknown quantity at this point
Final Programming Questions
As the last few days unroll, got a few more quests for anyone who can answer:
Distance per count - the Labview documentation uses an example of 64 times per rotation of the wheel. How I know this for our situation? is the default 64? Is this the value of 'Minimum Rate' that I set in the Config timer?
We are not using a camera in the competition. Since we are not using it, should I remove the camera init code in Basic Robot Main? Does it offer any benefit (lower startup time) ?
Unread 13-02-2009, 21:53
Re: Final Programming Questions
No need to keep it. I think the only difference will be in download time.
Greg McKaskle
Unread 14-02-2009, 01:19
ok, so you are allowed to remove the camera code? and what about the encoders?
Unread 14-02-2009, 07:47
It is only template code, kind of like other KOP. It is probably wise to start with it, but no need to use it all.
I don't understand the encoder question. There was no default code for doing encoders. There are examples that you could incorporate.
Greg McKaskle
Unread 14-02-2009, 08:50
ok, I just do not know if I should use the defaults put in the example for our robot, or if I am supposed to derive something special
Unread 14-02-2009, 10:05
Luke Pike's Avatar
Luke Pike Luke Pike is offline
Programmer
FRC #1501 (THRUST)
Luke Pike is a name known to allLuke Pike is a name known to allLuke Pike is a name known to allLuke Pike is a name known to allLuke Pike is a name known to allLuke Pike is a name known to all
You need to find the specs for the encoders. I think the encoders in the kit of parts is 250 ppr. We found that the Andy Mark wheels traveled about 19.5 inches for one turn. Divide that by the ppr and you should have your distance per count.
Twitter Profile
Relay Programming Questions... comwiz7 Programming 11 21-02-2006 13:04
Programming Questions magical hands Programming 14 26-01-2006 17:26
Final Render Questions BadKarma 3D Animation and Competition 7 20-02-2005 01:40
2 questions (programming) Brawler006 Programming 20 22-02-2004 23:15
3 Questions!!! Final Standings! Andy Grady General Forum 1 22-02-2004 22:32
