Go to Post To my surprise, purple painted air tanks were illegal last year. AB - Andy Baker [more]
Thread Tools Rating: Thread Rating: 4 votes, 4.00 average. Display Modes
Unread 13-02-2009, 14:20
huskyrobotics huskyrobotics is offline
FRC #0848
huskyrobotics will become famous soon enoughhuskyrobotics will become famous soon enough
Tank Drive Code?
I'm the lead (student) programmer for team 848. We can't for the life of us get the tank drive system to work. Right now I'll explain what we have in coding and our Screen Caps from our CPU. Right now we have a Tank Drive VI inside the "While Loop" with 2 Open Joystick VIs outside the "while loop." I know that the sole Open Solenoid VI is a problem, but right now I just need the robot in a driveable state. Looking at our screenshots, are there any obvious mistakes that would keep us from driving right now in tank style? I should state that like alot of teams, we are just learning to do anything in LabVIEW and have no prior programming experience whatsoever. Any help is appreciated. Thanks.
Unread 13-02-2009, 21:09
professorX professorX is offline
AKA: Xavier
FRC #1660 (The Harlem Knights)
professorX is an unknown quantity at this point
Re: Tank Drive Code?
You should try using the tank drive example that Labview included.
Unread 13-02-2009, 23:33
KayyPii's Avatar
KayyPii KayyPii is offline
FRC #1404 (SHOCKs)
KayyPii will become famous soon enough
Have you tried to run the robot on real-time tether?
If you run the dashboard program while your robot is running on real time, you can check your PWM outputs aswell. That way you know if its a programming problem or something else.
=>"That hole you drilled is a little off."
=>"Don't panic, just make it bigger and put a washer on it!"
=>Eye ball once, and cut as many times as it takes
Unread 14-02-2009, 07:45
I don't see anything wrong with the code. Make sure that you don't have a disabled robot, and describe what you see. Do the buttons respond to the joystick? If you probe the axis wires, do the numbers make sense?
Greg McKaskle
Unread 15-02-2009, 17:30
RedWolf55AJ RedWolf55AJ is offline
FRC #0848
RedWolf55AJ is an unknown quantity at this point
We tried that. When we plug in our IP Address and Deploy/Run, no inputs work at all, as if the VI was blank. This is without changing anything on the Tank Drive Example.vi mind you. We can't understand why it is like it is.
Unread 15-02-2009, 20:57
Are you sure that no inputs are working? Probe the joystick axis output values to see if they change as expected when you move the joysticks. If the probes follow the joystick motion, then you've isolated the problem to the outputs, and you can focus your troubleshooting on that part.
The easiest troubleshooting step is to look at your Driver Station display and make sure it says "Enabled" and "Teleoperated", and that it shows a reasonable battery voltage.
Unread 15-02-2009, 22:41
FRC #0848
Umm, Battery Voltage has always said "0.00" Is that a bad sign? Even when our robot drove, the driver station reported 0 voltage.
As far as probes go. The Probe on the wire from the "Get Axis" VI (the one connected to USB Port 1) reads like it should. the (Y axis reads correctly.) but the probe reports that the input is coming from USB Port 3. Thus no movement I guess...
For the Second "Get Axis" VI (the one connected to USB Port 2) no data is recorded. no matter what we do to the joystick, the probe reports nothing...
Unread 15-02-2009, 23:20
Best Available Data
FRC #1778 (Chill Out!)
This happened to us a couple of times today. Typically, it would be accompanied by some slightly odd robot behavior. Restarting the robot seemed to do the trick, but it was obnoxious to wait for for the blinking to start so we could resume testing.
Unread 16-02-2009, 13:16
jmanela's Avatar
jmanela jmanela is offline
+1 is BIGGER than -1
AKA: Joshua Manela
FRC #2586 (Fondy Fire)
jmanela is a splendid one to beholdjmanela is a splendid one to beholdjmanela is a splendid one to beholdjmanela is a splendid one to beholdjmanela is a splendid one to beholdjmanela is a splendid one to beholdjmanela is a splendid one to behold
made sure to close the tank drive vi at the end of the while loop
||2009|| Entrepeneurship Award, QF - Traverse City | Rookie All Star, QF - Detroit | Highest Rookie Seed, Rookie All Star, QF - Michigan State Championship | Finalist - MARC ||2010|| Engineering Inspiration, Website Award, SF- Kettering | Judges Award, Website Award, SF - Detroit | Website Award, Winner, Michigan State Champ //Thank you 469 and 1918!! | Finalist - MARC ||2011|| Engineering Inspiration, Website - Kettering | Entrepreneurship, Website, Finalist - Waterford | Website - MSC
Unread 16-02-2009, 22:04
blackdeath's Avatar
blackdeath blackdeath is offline
AKA: Shawn
FRC #2506 (Saber Robotics)
blackdeath is an unknown quantity at this point
Not related at all to your error, but down at the bottom of your code (first image) you are setting PWM4 and PWM5 to 255. The pwm outputs this year are NOT like last year's. Last year, it was from 0 to 255, with 0 being full reverse and 1 being full forward. This year, it is from -1 to 1, and I have not yet figured out which one is which for the axes, throttle, or motors.
Tank Drive Sauce Programming 1 05-01-2009 18:50
Where is tank drive in 2005 code? scottmso Programming 7 08-02-2006 22:03
omni drive vs tank |20807 61|2|_ Technical Discussion 49 17-01-2006 13:54
Tank Drive Idaman323 Programming 14 15-02-2005 09:01
tank drive Stormhammer Programming 11 29-01-2004 23:08
