Go to Post I am not a moderator, but I am John V-Neun. - Billfred [more]
Unread 13-02-2009, 22:15
camper365 camper365 is offline
FRC #1599
camper365 is an unknown quantity at this point
Axis 3 on joystick
I am trying to use the dial on the bottom of the joystick, and I know that it's Axis 3. The problem is that the bottom of the dial (all the way down) is -1 and the top is 1. I want to make the bottom 0 and the top 1. Is there any way I can do that.
I have tried Absolute Value, but that makes the bottom 1 and the top 1 (the middle 0). Is there a way to recalibrate the axis in the code?
Unread 13-02-2009, 22:22
TotalChaos's Avatar
TotalChaos TotalChaos is offline
AKA: Austin
FRC #2837 (Freebird Robotics)
TotalChaos has much to be proud ofTotalChaos has much to be proud ofTotalChaos has much to be proud ofTotalChaos has much to be proud ofTotalChaos has much to be proud ofTotalChaos has much to be proud ofTotalChaos has much to be proud ofTotalChaos has much to be proud ofTotalChaos has much to be proud ofTotalChaos has much to be proud of
Send a message via MSN to TotalChaos
Re: Axis 3 on joystick
You could simply add 1 to the output and then divide that value by 2.
- Austin
The 39th Aero Squadron - Team 39! (Visit our website!)
Team Role: 3 Years as Driver - College Student/Mentor!
Freebird Robotics - On a 1 year hiatus! (Visit our website!)
Arizona 2009: Semifinalists! (69 and 498), Delphi "Driving Tomorrow's Technology" Award
Unread 13-02-2009, 22:24
FRC #1599
that's all I need. I knew it wsa something simple, but I couldn't think of it right then (what I really hate is when that happens on my math test)
Unread 13-02-2009, 22:49
TotalChaos's Avatar
AKA: Austin
Haha I'm with you there. ... That happens way more often then I'd like..
- Austin
Reversing the joystick axis JBotAlan Programming 3 09-02-2005 19:47
Tri-axis Analog Joystick KVermilion Control System 5 19-01-2005 00:24
pwm outputs vs. joystick y-axis stephenthe1 Programming 4 01-12-2004 17:29
Inverting Y axis on joystick FormatteD_C Programming 7 24-02-2004 16:56
switching joystick axis????? team222badbrad Technical Discussion 9 16-01-2002 23:07
