Go to Post My opinion doesn't matter at inspection. - DonRotolo [more]
Unread 13-02-2009, 21:11
EHaskins EHaskins is offline
AKA: Eric Haskins
no team (CARD #6 (SCOE))
WiFi in pits
Has there been an official ruling whether WiFi will be allowed in the pits?
Eric Haskins KC9JVH
Unread 13-02-2009, 21:35
GBIT's Avatar
GBIT GBIT is offline
Lexantologist/Team Lead
AKA: Jared
FRC #0811 (Cardinals)
GBIT is just really niceGBIT is just really niceGBIT is just really niceGBIT is just really niceGBIT is just really nice
Send a message via AIM to GBIT
Re: WiFi in pits
I would assume if it is anything like last year you will need to teather the robot for any testing/running of the robot in the pits....
I will find the rule and site it give me a min...
[EDIT] Found it:
Every team should know, understand, and follow
the safety rules.
• Do not run in the venue.
• Wear closed-toed shoes to protect feet and toes.
• Charge batteries in an open, well-ventilated area. Do not charge near an open flame or
near equipment that may produce sparks. Do not use smoking materials in the battery
charging area. Charge in an upright position. It is not safe to charge the SLA battery in
an inverted position. Should your battery leak, ask the Pit Administration Supervisor for
baking soda to absorb the acid.
• Open flames are not allowed in any of the buildings
• Only the drayage company may handle loading robots in and out.
• Robots may be operated via wireless control only on the competition or practice fields.
• Two-way radios are not allowed.
[/EDIT]
hope that helps
Unread 13-02-2009, 21:37
ATannahill ATannahill is offline
AKA: Alex Tannahill
Re: WiFi in pits
It is in update 12, but I believe he is talking about a wireless network.
- Arizona North
Unread 13-02-2009, 23:08
AKA: Eric Haskins
Re: WiFi in pits
Yes, I'm taking about for purposes other than robot control.
Eric Haskins KC9JVH
Unread 13-02-2009, 23:18
Rick Wagner's Avatar
Rick Wagner Rick Wagner is offline
FRC #3008 (Kalani Robotics)
Rick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to behold
Re: WiFi in pits
Update 12 amends the rules to prohibit wireless control on practice fields.
Unread 13-02-2009, 23:23
Re: WiFi in pits
Wireless computer network adpaters are radios, and therefore I would think they are forbidden.
Unread 13-02-2009, 23:34
wt200999's Avatar
wt200999 wt200999 is offline
Texas Instruments
AKA: Will Toth
FRC #3005 (Robochargers)
wt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud of
Send a message via MSN to wt200999
Re: WiFi in pits
They don't exactly specify if it is meant to be just robot communication. Otherwise things like cell phones would be dis-allowed under this rule...
I think it would not be beneficial to disallow wifi for scouting, pit cast etc...
Programming in LabVIEW? Try VI Snippets!
FIRST LEGO League 2004 - 2005
FRC Team 870 Student 2006 - 2009
FRC Team 3005 Mentor 2013 -
Unread 13-02-2009, 23:39
Re: WiFi in pits
Depends on how tough they are on the "no radios" rule. If they enforce it thoroughly, there would be no cell phones allowed either.
Unread 14-02-2009, 00:41
nathanww nathanww is offline
Hacker
FRC #1678 (Citrus Circuits)
nathanww is just really nicenathanww is just really nicenathanww is just really nicenathanww is just really nice
Re: WiFi in pits
I believe that cell phones have been technically banned for a while, but almost never enforced(it's hard to do with all the spectators). Anyway...
Is using wifi illegal? Probably, since in previous years radio devices have not been allowed, and those don't even work on the same protocol as the IFI radio modems.
Will using wifi hurt anything? Probably not. Wifi as a standard was built to coexist peacefully with other wifi networks, cordless phones, ,bluetooth systems,microwave ovens, and anything else that uses that part of the 2.4 and 5 ghz bands(and be default wifi systems will find frequencies not already in use). That's not to say some performance degradation won't occur--but from our experiences testing at a school with high levels of wireless traffic, the biggest source of performance degradation is e-noise and shielding problems from your own robot, and everything else is pretty minor.
Will you get caught using wifi in the pits? It depends. If you're hooked up to a robot, you're basically announcing your ID through your SSID and the destination of packets, o you'll be easy to track down. If you're more covert about it(i.e.using a seperate wireless system), the only way to track you will be to home in on the signal, and even this can be defeated, for example, by hopping SSIDs or having a mobile AP.
Get yer robot source code here!
Unread 14-02-2009, 03:28
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: WiFi in pits
The bizarre thing about this rule to me is that a number of these venues may have one or more wireless networks in place anyway. I know for a fact that the 10,000 Lakes Regional will have the U of M Wireless network accessible as I was using it from the video drop table last year in Williams Arena.
Unread 14-02-2009, 07:54
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Re: WiFi in pits
Originally Posted by Update 12
• Two-way radios or other form of wireless communications are not allowed (with the exception of the previous bullet).
No wifi allowed.
___________________
- Tennyson, Ulysses
Unread 14-02-2009, 07:56
DtD's Avatar
DtD DtD is offline
I hope the watchdog starves!
AKA: Pathogen David
FRC #2410 (The Metal Mustangs (Merged from 2334, Hazmat Robotics))
DtD will become famous soon enoughDtD will become famous soon enough
Re: WiFi in pits
Only 1024 Bytes are getting transmitted back and forth by the cRIO and Driver Station, I don't think degration will be any problem with Wireless N.
Last year we got WiFi in the area provided by the arena or some other higher-up being, I hope we will again this year, we used it to help keep our sponsors up-to-date!
~DtD
Unread 14-02-2009, 10:13
d235j d235j is offline
FRC #4454
d235j has a spectacular aura aboutd235j has a spectacular aura about
Re: WiFi in pits
In any case, regular Wi-fi works on the 2.4 GHz radio band, while the robot's radios work on the 5 GHz band. Therefore, there should be no problems. (Cell phones work on the 850 / 1900 MHz band so there shouldn't be problems with that either.)
Of course, this is from a practical point of view; I'm not sure about the rules here.
Unread 14-02-2009, 12:46
Re: WiFi in pits
My take on the intent of the rule prohibiting "wireless" communication is to prevent the Commander from talking to the Outpost Payload Specialist via walkie talkie headset or to prevent communication between the Commander and a scout in the audience. I don't think it's for technical reasons (interference prevention). That's an FCC concern. My take, not official. It would be nice if there were clarification on Q&A.
Unread 14-02-2009, 14:38
Chris is me's Avatar
AKA: Pinecone
Re: WiFi in pits
Has someone submitted something similar to this on Q&A? This is very important for a stand scouting system my team is working on.
Would it be against the rules to _use_ the 10k Lakes Wi-Fi network for communication?
wifi? compuwiz12 Scouting 5 19-01-2009 15:45
St Louis Wifi addictedMax Chit-Chat 1 28-02-2007 22:31
wifi at nats Alexander McGee Championship Event 7 14-04-2004 23:38
WiFi Video Broadcast in Pits at Nats 2004 HFSbF5 Championship Event 5 14-04-2004 09:54
Pits were great, venue was the pits... archiver 1999 17 23-06-2002 22:44
