Go to Post If the world was like ChiefDelphi, people would be more eager to help out, offer advice and encourage each other to better things... not a bad world, that. - MissInformation [more]
Unread 14-02-2009, 00:50
AKA: Dr. Brooks
no team (WRRF)
Problems with required software update
We updated our cRIO, Driver Station and WindRiver system with the versions noted in team update 12. We observed the following issues
with the "iterative robot" code:
* The problem we reported earlier with the analog inputs on the cRIO providing a stray value now and then is gone.
* The periodic loop frequency has dropped from 200hz to 50hz (a reasonable value) and this will throw off your use of loop counting to measure time.
* A race condition has appeared for the last cycle of the disabledperiodic call, where the switches on the driver station may, or may not, read properly. If you are reading switches here to store the desired autonomous mode, you will sometimes get zeros. You need to buffer the values from the prior iteration so that you can avoid the race condition if you are saving the autonomous mode read from the switches.
Have fun!
Eugene
cRIO update 3.0 problems Two-Face Programming 3 14-02-2009 10:06
Problems after 3rd update applied pheisinger FRC Control System 3 13-02-2009 22:47
New Control System Update Problems NinJA999 FRC Control System 3 29-12-2008 23:04
**FIRST EMAIL**/Control System Software Update Reminder Mark McLeod FIRST E-Mail Blast Archive 13 30-11-2008 21:05
Building fully flexible tail (several joints) with minimal actuation required sanddrag Technical Discussion 51 27-11-2005 18:05
