Go to Post If I understand what you're saying, you don't understand very far. - Alan Anderson [more]
Unread 14-02-2009, 03:30
BurtGummer BurtGummer is offline
Electrical/Mechanical/Programming
FRC #3020
BurtGummer will become famous soon enoughBurtGummer will become famous soon enough
Pneumatics........
Quick question, can we ONLY order actuators from Bimba? We just changed a design that will likely need a pneumatic actuator. However, getting one from Bimba this close to the end is not an option, but we can do a will call for McMaster.
So, can we use pneumatic cylinders from McMaster-Carr as long as it is 1-1/16" Bore and an 8 inch stroke (double acting)? If not, does anyone have an suggestion of how to tip a hopper without using an actuator?
Thanks! This is our first year, and we just started last week due to several delays.
Unread 14-02-2009, 04:33
CDH Jeff's Avatar
CDH Jeff CDH Jeff is offline
FRC #2450 (Raiderbots)
Team Role: Electrical
CDH Jeff is an unknown quantity at this point
Re: Pneumatics........
stepper motors are pretty cool, and depending on if your platform is small or not you could order the HS 475HB servos for 18 bucks from servocity, because they're like the KOP servos on low scale steroids. as for pneumatics im not much help, our team isn't using them this year, and we barely knew what we were doing last year. hope this helps.
"why are 'standard' and 'metric' different?! metric should be the standard!"
Unread 14-02-2009, 05:00
Aren_Hill's Avatar
Build Nifty Things
http://forums.usfirst.org/showthread.php?t=11322
there you are, order away
A guy who likes robots.
Unread 14-02-2009, 14:10
FRC #3020
Awesome, thanks alot!
Unread 14-02-2009, 23:53
Originally Posted by CDH Jeff View Post
the HS 475HB servos
With a torque of 76 oz-in, those servos do not meet the requirements of <R51>B.
Unread 14-02-2009, 23:59
They do, however, meet the requirements of <R51-C>, which allows the FTC servos, which just so happen to be the HITEC HS-475HB.
Unread 15-02-2009, 11:03
purduephotog purduephotog is offline
Active Defense Design Engineer
AKA: Jason
FRC #3015
purduephotog is a jewel in the roughpurduephotog is a jewel in the roughpurduephotog is a jewel in the roughpurduephotog is a jewel in the rough
Send a message via AIM to purduephotog
Check Ebay.
If you were closer to Rochester I'd just give you one of our leftovers from last year/before.
Try a local team too- someone might have something.
I know I was able to order from our Bimba supplier in Syracuse and they had it on my desk on 2 days.... consider it part of your withholding allowance.
http://purduephotog.deviantart.com
Portrait Photography: "I used to say Immortalized in Silver, but now I say Captured and Squeezed by Electrons".
Pneumatics? falconmaster General Forum 6 19-01-2007 11:25
pneumatics CD archiver 2000 2 23-06-2002 22:46
pneumatics archiver 2000 1 23-06-2002 22:42
Pneumatics archiver 2001 1 23-06-2002 22:36
