Go to Post just want a picutre of my "CD idols" - Ryan Albright [more]
Unread 14-02-2009, 09:33
dani190 dani190 is offline
AKA: Dani
FRC #2185 (RoboRams)
dani190 is a splendid one to beholddani190 is a splendid one to beholddani190 is a splendid one to beholddani190 is a splendid one to beholddani190 is a splendid one to beholddani190 is a splendid one to beholddani190 is a splendid one to behold
Send a message via MSN to dani190
Team 2185: video of robot so far...
Hey guys here are 2 links to 2 videos of our robot as of last night...
I will be posting more today, hopefully with the shooter working and shooting balls...
http://www.vimeo.com/3212238
http://www.vimeo.com/3209327
Thanks
Unread 14-02-2009, 10:04
Re: Team 2185: video of robot so far...
Thanks
I'm curious as to why your cRIO modules are removed....I believe you can't do that.
Unread 14-02-2009, 10:28
AKA: Dani
ok so i put the 2 missing ones back in...
is that what you meant?
Unread 14-02-2009, 10:33
REVving up for a new season
FRC #2848 (All-sparks)
actually you can. The only modules that you need to leave installed on the cRIO are the 9201 Analog module in slot 1 with the battery monitoring jumper (<R64>) and the Digital module in slot 4 with the sidecar attached to run the Robot Signal Light <R58>.
All other modules can be removed if your team is not using them.
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 14-02-2009, 23:30
AKA: Dani
yea see i did think you could leave them out... There is no justifiable reason for them to be in...
Unread 15-02-2009, 00:06
Oh wow, thanks. Sorry for the earlier post then.
Unread 15-02-2009, 00:22
usbcd36's Avatar
usbcd36 usbcd36 is offline
AKA: "DOS"
FRC #2399 (The Fighting Unicorns)
usbcd36 is a jewel in the roughusbcd36 is a jewel in the roughusbcd36 is a jewel in the rough
I'm confused as to how the shooter is supposed to work. The sprocket on the CIM is lined up with one on the right shooter roller, and another sprocket on the right roller is lined up with the one on the left roller. I don't see an idler anywhere, which implies that both rollers would turn the same direction.
Unread 15-02-2009, 00:26
AKA: Dani
Well what i think you missed is our custom gear box under that plastic plate were the balls fall onto and get shot out...
That allows the rollers to roll in reverse directions...
We will have video up tomorrow hopefully of it actually shooting
Unread 15-02-2009, 09:15
AmoryG AmoryG is offline
FRC #2423 (KwarQs)
AmoryG has much to be proud ofAmoryG has much to be proud ofAmoryG has much to be proud ofAmoryG has much to be proud ofAmoryG has much to be proud ofAmoryG has much to be proud ofAmoryG has much to be proud ofAmoryG has much to be proud of
That robot looks like it could kill somebody.
KwarQs 2423
2008 Boston Regional Rookie Allstars
http://whsrobot.blogspot.com/
Unread 15-02-2009, 10:33
ttldomination's Avatar
Sunny
Just, I'm not sure if it's a video affect or if I'm mistaken, but looking at the robot coming down the hallway, it looks like your chassis is caving inward, which would make your wheels not lie a on plane which is 90 degrees from the floor...
Anyone else notice that or is it just me?
1648: 2013-2014
5283: 2015
Unread 15-02-2009, 11:32
Just to make sure, is there a Q&A you could point me to, Greg? Thanks.
edit: nvm I found it.
Yes, this is permitted (except you cannot remove the module in Slot #1, to preserve the battery monitoring function). If you do remove unused modules from the cRIO Mobile Device Controller, we highly recommend that you use the spare port covers provided with the controller to cover the exposed connections at the bottom of the cRIO to prevent foreign debris contamination.
Unread 15-02-2009, 16:06
sayso_411's Avatar
sayso_411 sayso_411 is offline
10 Years of Sparky!
AKA: Shaav
FRC #0384 (Sparky)
sayso_411 can only hope to improve
I noticed that too...maybe there is a bend in the frame?
Unread 15-02-2009, 16:58
AKA: Dani
no you are correct it is slightlly bending...
We just put a brace going across in so it now stays square i guess you could say...
Video: Team 498 Robot Teaser Video Cactus_Robotics Robot Showcase 5 17-02-2008 22:35
pic: So far.. inventored robot. Team 617 rohit Extra Discussion 9 27-02-2007 21:46
pic: 701's Robot so far Doug G Robot Showcase 3 16-02-2007 02:16
Video - Team 195 - 2006 Season So Far Tom Bottiglieri Robot Showcase 8 20-04-2006 23:03
pic: Team 1595 Robot So Far sgsdragons Robot Showcase 2 30-01-2006 17:38
