Go to Post Drive Trains are overrated - MaGiC_PiKaChU [more]
Unread 14-02-2009, 10:30
rl1806's Avatar
rl1806 rl1806 is offline
AKA: Ryan Lowe
FRC #1806 (S.W.A.T.)
rl1806 will become famous soon enough
Re: C++ Camera Problems
Our camera will be tracking the target then sometimes it just looses it and other times the camera turns to the left and acts like it has locked onto something. When it turns to the left we have to put something in front of the camera to get it to start searching again. We are using the latest update to the software.
2011-Present: SWAT FRC 1806 Mentor
2012 Rockwell Automation Innovation in Control Award [Oklahoma City]
Unread 14-02-2009, 18:09
elfinn elfinn is offline
Team 166 Mentor
AKA: Beth Finn
FRC #0166 (Chopshop Team 166)
elfinn is an unknown quantity at this point
There are two things that may help you. One is fixing a bug in Target.cpp's FindTwoColors() if you are using the sample program. Search for memcpy and change the second line of each memcpy pair to copy secondTrackReport instead of firstTrackReport to par2.
The other thing which I think is really your problem, is that the camera configuration / HSL settings are not working in your test environment. The camera acts like this if there is a bright contrast, glare or other lighting conditions that are less than ideal. There is a white paper on NI's web site that can help explain this:
http://joule.ni.com/nidu/cds/view/p/id/1235/lang/en
Camera problems(c++) Yuan Xue Lim Programming 12 04-02-2009 16:56
Camera Problems!!! spsteam1512 Programming 0 12-02-2007 13:45
Camera Problems CMB Programming 2 02-02-2007 18:24
Camera Problems 804_twidget1 Electrical 4 27-01-2007 11:28
Camera Problems pickle Programming 21 20-01-2005 20:43
