Go to Post Use sensors to collect data about the surrounding environment, then discard it and drive into walls. - Jared Russell [more]
Unread 14-02-2009, 10:54
pj174208 pj174208 is offline
Team 810
FRC #0810 (Mechanical Bulls)
pj174208 is an unknown quantity at this point
The Program Compiles and Deploys, but the sidecar doesn't connect
Okey, today our team tried to test out our new robot setup with the new code. We tried at least 5 times with different codes, which all compile and deploy successfully. However, the sidecar continues to blink slow and the compressor doesn't run. Please help, and respond.
Team 810 Bulls
Unread 14-02-2009, 18:26
Re: The Program Compiles and Deploys, but the sidecar doesn't connect
If you look at the errors coming from WPI, that will likely indicate that code and cRIO FPGA aren't the same version. The solution if that is the problem, is to reimage the cRIO to the most recent version. Be sure to check the checkbox to reformat.
Greg McKaskle
Run works but build&deploy doesn't program1 NI LabVIEW 3 03-02-2009 22:32
Getting to the 2008 Honolulu Regionals doesn't require breaking the bank da Marshalls Regional Competitions 113 10-01-2008 13:14
Carrying the ball under the overpass but across the finish line BaldGuy Rules/Strategy 13 09-01-2008 14:53
pic: 832 deploys the secret weapon! Tom Bishop Extra Discussion 21 25-04-2007 10:24
how do u connect the battery to the robot interface? chrisw Technical Discussion 1 10-01-2002 16:41
