Go to Post Aim for the stars – you just might hit a planet. - Leo M [more]
Unread 14-02-2009, 08:12
programmr's Avatar
programmr programmr is offline
AKA: Face
FRC #0522
programmr is a jewel in the roughprogrammr is a jewel in the roughprogrammr is a jewel in the rough
Send a message via AIM to programmr
Programmer a motor with a trigger
hello, the idea im trying to do is program leftStick Get Raw Button(1) to set the drive motors on pwm1 and pwm 2 leftmotor and rightmotor to run at a speed of .2, now if i have set 0.2 and set 0.2, the left motor goes in reverse, if i do -0.2, it doesnt move at all, what is the proper way to set these two motors to the same speed by holding a trigger?
"I would love to change the world but no one will give me the source code"
Unread 14-02-2009, 08:14
Re: Programmer a motor with a trigger
First make sure that the Open Motor or Drive ref is for the right kind of motor controller. The PWM period is different and especially talking to a victor as if it is a jaguar is not a good idea.
If that isn't it, try bumping the value a bit higher. -0.2 may not be enough to move it.
Greg McKaskle
Unread 14-02-2009, 08:34
programmr's Avatar
AKA: Face
FRC #0522
i tried that, but here let me give you the code i tried and maybe you could find somethign thats wrong
RobotDrive* myRobot;
Jaguar* leftmotor;
Jaguar* rightmotor;
myRobot = new RobotDrive(1, 2);
leftmotor = new Jaguar(1);
rightmotor = new Jaguar(2);
if (!ds->GetDigitalIn(ARCADE_MODE)) {
myRobot->TankDrive(leftStick, rightStick);
else {
myRobot->ArcadeDrive(leftStick);
if (rightStick->GetRawButton(1)) {
leftmotor->Set(-0.5);
rightmotor->Set(0.5);
else {
leftmotor->Set(0.0);
rightmotor->Set(0.0);
that's what i have, can someone please help tell me why the left motor doesnt work when i do this. if i have both positive numbers, then the left motor goes in reverse
Unread 14-02-2009, 08:39
I'm not a jaguar expert. Is there a jumper that affects this?
Greg McKaskle
Unread 14-02-2009, 08:41
programmr's Avatar
AKA: Face
FRC #0522
no there isnt a jumper that affects this.. does anyone else have any ideas?
Unread 14-02-2009, 12:47
programmr's Avatar
AKA: Face
FRC #0522
does anyone else have any ideas as to why this doesnt work....???? PLEASE HELP! Thank You
Unread 14-02-2009, 18:43
OK, I had more time to look up what I was thinking. The jaguar has jumpers that need to be installed if you are not using the limit switches. If you don't have the jumpers, I think that can result in a motor controller that will not move in one of the directions.
It seems like something to double check.
Greg McKaskle
Unread 14-02-2009, 19:06
Golto's Avatar
Golto Golto is offline
AKA: Pat Plude
FRC #4572 (BArlow RobAutics)
Golto is a glorious beacon of lightGolto is a glorious beacon of lightGolto is a glorious beacon of lightGolto is a glorious beacon of lightGolto is a glorious beacon of light
try this (modify as needed)
while (IsOperatorControl)
if (LeftStick.GetRawButton(1) == true)
    roller.Set(1.0);
if (LeftStick.GetRawButton(1) == false)
    roller.Set(0.0);
Wait(0.005);
LeftStick is your left joystick variable
Roller is the function to be used with the trigger
No need for semaphores, and don't worry, the cRIO is so fast, you'd never notice the lag.
This is part of 558's codebase. If you need more help email me:
pplude@freehugalliance.com
Unread 14-02-2009, 22:00
yarb65 yarb65 is offline
Coach
AKA: T Bray
FRC #3189 (Circuit Breakers)
yarb65 has a spectacular aura aboutyarb65 has a spectacular aura about
I think the original question was about getting a motor to reverse using a button. I have tried using a -1 and nothing happens when button is pushed. I am using a Victor and Windriver. If someone has actually done it, how?
2013 Sacramento Regional Winner (3189,701,2489))
2012 Israel Regional Winner (1662,1690,1937)
2008 Sacramento Regional Winner (1662,115,2122)
2006 Sacramento Regional Winner (1662,852,1726)
Unread 14-02-2009, 23:16
Golto's Avatar
AKA: Pat Plude
would something along the lines of
RobotDrive = RobotDrive * (-1);
work?
Please help with some questions~new programmer bilal1219 Programming 2 29-01-2008 11:44
New Programmer working with cmu cam2 pbrules15 Programming 13 14-07-2007 22:40
NEED PROGRAMMER TO HELP WITH PROGRAMING Reaper40 Programming 4 02-02-2007 17:31
pic: The programmer needs some alone time with the robot! Karthik1 Extra Discussion 7 23-02-2005 10:35
problems with our programmer AlphaOmega870 Programming 12 31-01-2003 08:23
