Go to Post I wouldn't need a bullet proof vest I would need bullet proof shorts. - rees2001 [more]
Unread 13-02-2009, 15:18
Norton Norton is offline
Computer Engineering
FRC #0383 (The Brazilian Machine)
Norton is an unknown quantity at this point
Send a message via MSN to Norton
Playstation controller
We are going to use a playstation like USB controller and Its working pretty well, but the analogs have a very small range, in the middle of the physical range it reports 128 to GET RAW or 1 to Joystick GET, how could I optimize this???
I tried to use the scale, but no luck...
Thanks
Unread 13-02-2009, 15:21
Re: Playstation controller
The joystick Get() method returns a floating-point value from -1 to +1. The neutral "middle" value should be 0. The range is not as important as the resolution, and the resolution is basically set by the hardware implementation in the controller.
Unread 14-02-2009, 12:48
Ok Alan... I know that, I would like to know if there is a way to "distribute" the axis in a more even way . . .
but I tried it on the computer and got the same results, thanks
Unread 14-02-2009, 20:28
What you may be looking for is a nonlinear mapping. You might try squaring the joystick value before sending it to the motor. That will give you a more gradual action away from zero. Going the opposite directly, a sign preserving square root would be interesting.
Greg McKaskle
playstation first controller starsROBOTICS Programming 4 23-03-2008 23:28
playstation 2 controller to transmitter starsROBOTICS Control System 0 22-03-2008 21:58
Playstation controller code help haywirerobotics Programming 4 25-01-2007 00:16
playstation controller conversion jpyro Electrical 6 31-01-2006 17:52
Connect Playstation Controller to PC USB. kirov Control System 1 28-02-2005 08:24
