Go to Post Sometimes the best feeling doesn't come from watching yourself excel but rather from watching others excel. - kristenliz_28 [more]
Unread 14-02-2009, 12:49
dani190 dani190 is offline
AKA: Dani
FRC #2185 (RoboRams)
dani190 is a splendid one to beholddani190 is a splendid one to beholddani190 is a splendid one to beholddani190 is a splendid one to beholddani190 is a splendid one to beholddani190 is a splendid one to beholddani190 is a splendid one to behold
Send a message via MSN to dani190
axis camera power cable falling out..
Hey guys, has anyone had an issue with the axis camera power cable following out constantly...
We cant drive for a few minutes without it falling out...
any ideas?
Unread 14-02-2009, 13:03
Urban Hawk Urban Hawk is offline
Head of R&D and Head of Scouting
FRC #1886
Team Role: Scout
Urban Hawk is infamous around these partsUrban Hawk is infamous around these partsUrban Hawk is infamous around these parts
Re: axis camera power cable falling out..
use duck tape or some other fastener to hold it in place.
FEAR THE HAWK!!!
Justin Stiltner's Avatar
Justin Stiltner Justin Stiltner is offline
The big guy
Justin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud of
Send a message via ICQ to Justin Stiltner Send a message via AIM to Justin Stiltner Send a message via MSN to Justin Stiltner Send a message via Yahoo to Justin Stiltner
hot glue, or shoe goo (clear glue that dries to a rubbery consistency, like E9000), just a little bit to hold it in, If you want to remove it you can simply pull the glue off
Justin Stiltner
Lead Robot Inspector, VCU Regional
Unmanned Systems Lab, Virginia Tech
KI4URQ
Unread 14-02-2009, 13:13
FRC #1886
Team Role: Scout
well i dislike the use of glue because of it's drying period and the fact you can make a mess of it.
FEAR THE HAWK!!!
Unread 14-02-2009, 13:58
AKA: Dani
well the only thing is il put it in and then it wont turn on again for some reason...
n then it will randomly go online again
Unread 14-02-2009, 14:33
FRC #1886
Team Role: Scout
then it seems the problem is beyond just it falling out.
as to why it would do that i have no idea
FEAR THE HAWK!!!
Unread 19-02-2009, 08:14
Double check that the center pin is not bent. Both conditions you describe relate to the center pin not being in position enough to provide good contact with the center contact of the power cable. Double check that the center pin is in the camera and not broken off inside the power cable.
Unread 19-02-2009, 13:55
A Bear's Avatar
A Bear A Bear is offline
FRC #2333 (Roboswitch Engage)
Team Role: Student
A Bear is an unknown quantity at this point
you could glue a piece of wood to the side so that the belt cant fall out
Need help with Axis 206 Power Adapter dipmeinaluminum FRC Control System 1 21-01-2009 20:01
Can't figure out the Axis camera setup... 2829ron Technical Discussion 6 20-01-2009 13:12
2007 Controller Power cable? reflion Electrical 7 16-01-2009 07:33
AXIS Camera nickmagus Programming 1 03-01-2009 20:06
Camera power cable MustangRobotics General Forum 11 12-01-2006 22:39
