Go to Post please....Mr. Needel is my father :rolleyes: - Greg Needel [more]
Unread 14-02-2009, 14:34
ringo115 ringo115 is offline
FRC #1647
ringo115 is on a distinguished road
question regarding driverstation
So we just updated our drivers station and everything seemed fine, however now rather then saying its enabled or disabled it was watchdog, what does that meen?
Unread 14-02-2009, 17:18
BEEKMAN BEEKMAN is offline
AKA: Brendan McLeod
FRC #0190 (Gompei and the Herd)
BEEKMAN is a splendid one to beholdBEEKMAN is a splendid one to beholdBEEKMAN is a splendid one to beholdBEEKMAN is a splendid one to beholdBEEKMAN is a splendid one to beholdBEEKMAN is a splendid one to behold
Re: question regarding driverstation
it means that somewhere, your code failed...not sure why though, we've yet to get this
Unread 14-02-2009, 19:34
lynca's Avatar
lynca lynca is offline
Andrew Lynch
FRC #2587 (DiscoBots)
The best way to debug coding failures is to look closely at the default project. Open a default project on another computer and compare with your current project.
Be careful about where you initialize watchdogs and what variables pass through case statements and loops.
History: 624 - Cryptonite --> 118 - Robonauts --> 2158 - AusTIN CANS --> 2587 DiscoBots
Bio: Andrew Lynch "How I Work" ---- LinkedIn , Facebook, Twitter
Unread 16-02-2009, 10:47
FRC #1647
can you reccomend a good place to initalize said watchdog, and where is a good place to learn about the watchdog
Unread 16-02-2009, 11:16
The watchdog is initialized and fed for you if you start with one of the provided project templates. The only time you really need to worry about it is if you want to do debugging using breakpoints. You just have to write your code to avoid tying up the processor in long loops waiting for something to happen without feeding the watchdog.
Question Regarding Torque - Pulling CollmandosGrl Technical Discussion 2 31-01-2008 17:56
Simple question regarding OI LED's Tom Line Programming 3 29-01-2008 12:03
Question regarding to Battery Packaging sxlterps General Forum 1 19-02-2005 17:37
Question regarding Florida archiver 2001 1 24-06-2002 03:00
