Go to Post Mentors are here to guide and explain not to decide and do. - Fe_Will [more]
Unread 14-02-2009, 15:14
Jill Jill is offline
FRC #2197 (Las Pumas)
Jill is an unknown quantity at this point
RSL blinking/not working
Our team hooked up the RSL to the digital sidecar, just like the power diagram. Sometimes it works for a second, then starts blinking. Sometimes it blinks as soon as it gets power. On the digital sidecar, there's a little green light right by where the RSL is connected, and that's blinking. We've checked the connections and can't find anything wrong there. Everything else attached to the digital sidecar works fine. My teammates and I were under the assumption that the light is supposed to be solid. Is that correct? Has anyone else had this problem?
Unread 14-02-2009, 15:49
EricH EricH is online now
Re: RSL blinking/not working
The small LED's meanings can be checked at http://decibel.ni.com/content/docs/DOC-3120
It sounds like either you have bad communication or the robot is disabled.
Unread 14-02-2009, 19:40
lynca's Avatar
lynca lynca is offline
Andrew Lynch
FRC #2587 (DiscoBots)
The light should be solid when your robot is enabled. It will blink when its disabled. Does your robot randomly become disabled or is the light just randomly blinking even when your robot is enabled ?
History: 624 - Cryptonite --> 118 - Robonauts --> 2158 - AusTIN CANS --> 2587 DiscoBots
Bio: Andrew Lynch "How I Work" ---- LinkedIn , Facebook, Twitter
Unread 15-02-2009, 00:03
PhilBot's Avatar
PhilBot PhilBot is offline
Get a life? This IS my life!
AKA: Phil Malone
funny, our BFL does the same. When the led flashes, so does the light. But when the led is solid on, the lamp still flashes. It's as if the lamp has a flasher bulb like a Xmas tree light.
We only have two of the lamp connections wired. I keep telling the kids to check the wiring diagram.
Phil Malone
http://www.GEARSinc.org
Unread 15-02-2009, 00:53
The lamp basically does have a flasher in it. The extra wire specified between the outer two connections disables it.
Unread 16-02-2009, 08:09
The large, external RSL needs to have a jumper installed. The jumper is installed between the La adn Lb pins at the light connector per the Robot Power Distribution Diagram.
jaguar not working Bwood16 Motors 12 13-02-2009 13:22
Camera not working... AG-chadd Programming 4 04-02-2009 22:10
Remembering not working EricH CD Forum Support 9 21-07-2008 07:43
p2 not working? Lone_Wolf92c Programming 5 22-02-2008 08:49
IR Board Not Working (But NOT Fried) itsme Electrical 2 18-02-2008 06:11
