Go to Post If winning that individual match is more important to you than being there in the first place, then I believe you've got your priorities in the wrong spot. - Tom Bottiglieri [more]
Unread 14-02-2009, 13:02
VeedotJaydot VeedotJaydot is offline
FRC #1379
VeedotJaydot is an unknown quantity at this point
Using Limit Switches in LabVIEW
I'm confused on how to use limit switches in labview, first off, are they digital or analogue, and where is the .vi that opens limit switches?
Unread 14-02-2009, 15:18
chmp09 chmp09 is offline
AKA: Marc Pulte
FRC #1702 (Robocubs)
chmp09 is a jewel in the roughchmp09 is a jewel in the roughchmp09 is a jewel in the rough
Re: Using Limit Switches in LabVIEW
Limit switches are digital. All you have to do is use the dio in open vi to initialize the port. The dio in get vi will return a boolean.
Unread 14-02-2009, 16:01
airnate airnate is offline
FRC #0236 (Techno Ticks)
airnate is a jewel in the roughairnate is a jewel in the roughairnate is a jewel in the rough
The DIO (Digital Input Output) VI that chmp09 refers to is in
WPI Robotics Library-> IO -> DigitalInput -> GetValue.vi
The digital input will typically default to True (e.g. is electrically pulled up to +5V) so if you wire a normally open (N.O.) limit switch between the signal pin and the ground pin, the GetValue.vi input will go False when the switch is closed.
Limit Switches popnbrown NI LabVIEW 1 10-02-2009 22:39
Toggling boolean using 2 limit switches Quarkster NI LabVIEW 2 02-02-2009 22:43
Limit switches(in C++) beefy1 Programming 3 24-12-2008 15:27
Using Limit Switches with the Arm iwin2000 Programming 3 18-02-2008 03:52
Limit Switches ChrisR_522 Programming 2 25-01-2008 08:04
