Go to Post I don't get what all you people have done wrong to make the drills have so many problems. - Cory [more]
Unread 14-02-2009, 16:04
windell747 windell747 is offline
FRC #2477
windell747 will become famous soon enoughwindell747 will become famous soon enough
Re: Problems with using 330's goal tracking code
Thanks for your help! It looks like I was able to get the response to converge. here are my gains for anyone interested. x-axis0.003,I0.5. y-axis: P0.015,I0.70. derivative terms 0. max x=0.45,max y=0.7
I'm trying to plot the x and y axis outputs to a graph but im having some trouble. I'm using the plot waveform and feeding to the input a get waveform time array, but im not getting the correct data types. Can anyone briefly explain the process to do this?
Thanks!
Unread 14-02-2009, 16:14
airnate airnate is offline
FRC #0236 (Techno Ticks)
airnate is a jewel in the roughairnate is a jewel in the roughairnate is a jewel in the rough
One of the easiest ways to do this is to:
1. Go to your Front Panel
2. Select Express->Graph Indicators->XY Graph (aka Express XY Graph)
3. On the block diagram, wire your X and Y inputs
4. Double click the Build XY Graph on the block diagram and turn off Clear Data on Each Call.
-Nate
Unread 15-02-2009, 22:57
FRC #2477
how do you put time values for the x variable each iteration? I guess I could just put a counter that increments, but im not sure how to do this either. I would like to not use a for loop. Any suggestions?
Unread 16-02-2009, 13:02
Sorry, I assumed you wanted an XY plot (plotting one variable against another). If you have two independent variables to plot, then use a Chart.
Bundle the two values (presumably X and Y) together and then wire to the Chart terminal.
Problems with tracking Shinsa Programming 2 07-02-2010 14:35
Using kevin's code for driving and camera tracking razzoc Programming 3 18-02-2007 08:50
Enabling Multiple Light Tracking Using Kevin's Code Mitch Programming 7 05-02-2007 06:17
problems using gyro/adc code with camera default code tanstaafl Programming 7 22-01-2006 23:09
Problems tracking with CMUCam2 in LabVIEW PhilBot LabView and Data Acquisition 5 17-01-2006 20:42
