Go to Post Nonetheless, I would welcome it, as long as [The President] didn't restrict the number of discs that a Robot could hold. Oops, wait, too late, the GDC already did that. :-) - MooreteP [more]
Unread 14-02-2009, 16:14
furiousgeorge's Avatar
furiousgeorge furiousgeorge is offline
FRC #3055
furiousgeorge will become famous soon enoughfuriousgeorge will become famous soon enough
Joystick Sensitivity
is there a way to make the acceleration of the motors that are controlled by the joysticks more of a logarithmic acceleration so that our driver does not have to comensate as much for the sensitivity of the joystick controls?
Unread 14-02-2009, 16:20
airnate airnate is offline
FRC #0236 (Techno Ticks)
airnate is a jewel in the roughairnate is a jewel in the roughairnate is a jewel in the rough
Re: Joystick Sensitivity
Well, you can certainly manipulate the joystick value and make your own transform function. The logarithms are in the following palette:
Mathematics -> Elementary -> Exponential Functions
If you prefer to use text to define the mathematical formula, you can use the Formula Node located in :
Mathematics -> Scripts & Formulas -> Formula Node
Drop a Formula Node on your block diagram and right click it and select Help to see how it works.
I also thought I remembered seeing a place that WPI provided in the Robotics library to add your own lookup table to the motor scaling, but I've forgotten where I saw this.
[I spoke to our Senior Control Mentor and he told me the motor scaling is done in the example code "Custom Motor Scaling"].
1. To see the Custom Motor Scaling Example, select View->Getting Started Window... from the menubar, or it will appear when you first open LabVIEW.
2. Select Examples -> More... (lower right corner of window)
3. Select Custom Motor Scaling Example.
Unread 19-02-2010, 19:26
JP Carlin's Avatar
JP Carlin JP Carlin is offline
FRC #2487 (Mechanical Animals)
JP Carlin is on a distinguished road
honestly all i did when i needed to make a joystick less sensitive i just divided the value of the joystick by a constant of 2 before it reached the set speed of the motor. this made it only half as fast as it was originally but it also reduced its power.
Unread 19-02-2010, 21:46
try this instead:
http://www.chiefdelphi.com/forums/sh...d.php?p=921992
Unread 19-02-2010, 23:13
JP Carlin's Avatar
i looked at that post when i was trying to work out the sensitivity on my controller although i had a little trouble grasping that concept. last year our one programmer graduated. he got pretty angry at the way the club was run and never taught anyone else how to program, so this being my first year i figured i would go with more simplistic ways to program.
Unread 21-01-2014, 22:12
Team3993Tom Team3993Tom is offline
FRC #3993
Team3993Tom is an unknown quantity at this point
can some one please post a pic of there code, im new to labview.
Unread 21-01-2014, 22:20
Dexterium's Avatar
Dexterium Dexterium is offline
AKA: Adam Poindexter
FRC #1208 (Metool Brigade)
Dexterium is an unknown quantity at this point
If you square the joystick value you will get a slower increase in power while still reaching 100% power and that should be just what you need.
Joystick input vs output graph below
Unread 21-01-2014, 22:26
FRC #3993
thank you for the fast reply, but I have no idea how to do that or implant it into the code.
Unread 22-01-2014, 12:37
gpetilli gpetilli is offline
FRC #1559
gpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to all
We always square the joystick before using to improve fine motor coordination.
minor (but important) clarification - to preserve the sign:
joy2 = joy * abs(joy);
Unread 22-01-2014, 13:06
If you want to be able to fine-tune the sensitivity adjustment, try this instead:
Joyadj = a*(Joy3) + (1-a)*Joy,
where "a" is a constant in the range 0<=a<=1.
By changing "a" in that range, you get a family of curves lying between the curve Joyadj=Joy and Joyadj=Joy3.
When a=0 you get Joyadj=Joy, and when a=1 you get Joyadj=Joy3. When 0<a<1, you get a "blend" in-between Joyadj=Joy and Joyadj=Joy3. The range of Joyadj is still -1 to +1 for all curves in the family.
More detailed explanation here.
Unread 22-01-2014, 20:47
Dexterium's Avatar
Here's some code. You can implement the more complex form ether posted, but this is the most basic form and all that most teams need. Sorry for not including it the first time.
Unread 22-01-2014, 21:09
I don't know about LabVIEW, but the WPILib RobotDrive already has code in it to square the inputs if you want.
So if all you want to do is square the inputs, you don't need to do that in your code.
Unread 26-01-2014, 19:50
FRC #3993
ok so that seemed to work a little but it's still sensitive. It was originally so bad that if you picked up the controller it would move like a bat out of hell and ram into the wall. So what else do you think I should do
Unread 26-01-2014, 20:16
sanelss sanelss is offline
FRC #1658
sanelss is a splendid one to beholdsanelss is a splendid one to beholdsanelss is a splendid one to beholdsanelss is a splendid one to beholdsanelss is a splendid one to beholdsanelss is a splendid one to behold
I'll post you the vi I made earlier today just for this purpose. There are several ways this VI can be used and there's a few more features I want to add before I publish it. I'll also upload a video demonstrating the effects of all the different features. I had functions setup previous years that did everything I needed but this year I decided to wrap it up into a nice re-usable general purpose package with no drawbacks.
Unread 27-01-2014, 00:39
FRC #1658
Here is the vi and video explaining it as promised:
https://drive.google.com/file/d/0B4f...it?usp=sharing
https://www.youtube.com/watch?v=5pDs...ature=youtu.be
joystick sensitivity gabrielse Programming 2 08-02-2008 14:52
Joystick sensitivity Philz20 Programming 10 24-01-2008 08:34
joystick sensitivity hanan Control System 4 19-01-2007 05:36
joystick sensitivity Team 668 Programming 11 16-02-2005 18:45
Help with Joystick Axes and Sensitivity bglass Programming 6 06-02-2005 14:01
