Re: Problems with using 330's goal tracking code
One of the easiest ways to do this is to:
1. Go to your Front Panel 2. Select Express->Graph Indicators->XY Graph (aka Express XY Graph) 3. On the block diagram, wire your X and Y inputs 4. Double click the Build XY Graph on the block diagram and turn off Clear Data on Each Call. -Nate |
how do you put time values for the x variable each iteration? I guess I could just put a counter that increments, but im not sure how to do this either. I would like to not use a for loop. Any suggestions?
Sorry, I assumed you wanted an XY plot (plotting one variable against another). If you have two independent variables to plot, then use a Chart.
Bundle the two values (presumably X and Y) together and then wire to the Chart terminal. |
| Problems with tracking | Shinsa | Programming | 2 | 07-02-2010 14:35 |
| Using kevin's code for driving and camera tracking | razzoc | Programming | 3 | 18-02-2007 08:50 |
| Enabling Multiple Light Tracking Using Kevin's Code | Mitch | Programming | 7 | 05-02-2007 06:17 |
| problems using gyro/adc code with camera default code | tanstaafl | Programming | 7 | 22-01-2006 23:09 |
| Problems tracking with CMUCam2 in LabVIEW | PhilBot | LabView and Data Acquisition | 5 | 17-01-2006 20:42 |
