Go to Post What's the reason for having a rule if it's not enforced? - jpsaul7usa [more]
Unread 14-02-2009, 16:38
brainsdmaner's Avatar
brainsdmaner brainsdmaner is offline
AKA: Brian
FRC #1691
brainsdmaner is an unknown quantity at this point
Crio image download
Ok...i feel incredibly stupid right now, but am i the only one who has had problems finding the place were you can download the new crio image?
Everywhere i have found so far to tell me where to go just says got here 'www.usfirst.org/frccontrolsystem' and i haven't been able to find anything on the links from there leading a place like that.
I would remedy a lot of my problems right now if someone would simply provide a url for the download page!!
And I'll just put a thank you here in advance for any help you guys can give.
Unread 14-02-2009, 19:51
EHaskins EHaskins is offline
AKA: Eric Haskins
no team (CARD #6 (SCOE))
Re: Crio image download
The image is included in the LabView Update, it will appear as an option in the cRio imaging tool:
http://joule.ni.com/nidu/cds/view/p/lang/en/id/1180
Or its available as a standalone updater with the C++ updates:
http://first.wpi.edu/FRC/frcupdates.html
You should also update your DS firmware the file is here
http://usfirst.org/uploadedFiles/dsud_pkg(1).bin
and instructions are here
http://usfirst.org/uploadedFiles/Upd...structions.pdf
Eric Haskins KC9JVH
Unread 15-02-2009, 01:06
The cRIO image is included in the LabVIEW update.
Cannot get Code to Download to cRIO greekgod8591 C/C++ 25 09-03-2009 22:10
cRIO Image version? Chris11246 Programming 1 14-02-2009 16:44
v11 cRIO Image Error Team1710 Programming 7 14-02-2009 12:56
Download Programs Off the cRIO jwdickson FRC Control System 1 10-01-2009 17:29
Unable to re-image cRIO slavik262 FRC Control System 4 09-12-2008 21:05
