Go to Post What we may be looking at is a confusing situation and that can be confusing. - JaneYoung [more]
Unread 14-02-2009, 16:14
Derek Allen's Avatar
Derek Allen Derek Allen is offline
Head Programmer
FRC #1785 (Jagwired Robotics)
Derek Allen is an unknown quantity at this point
Send a message via MSN to Derek Allen Send a message via Yahoo to Derek Allen
Joystick Library broken?
I accidentally the whole Joystick Get library button variables. Is there a way i can repair what i've done?
Unread 14-02-2009, 16:22
airnate airnate is offline
FRC #0236 (Techno Ticks)
airnate is a jewel in the roughairnate is a jewel in the roughairnate is a jewel in the rough
Re: Joystick Library broken?
Can you clarify? Did you delete / modify the Joystick Get.vi itself?
Unread 14-02-2009, 16:29
Head Programmer
I only deleted the button booleans, making it so that i can't use the buttons at all.
Unread 14-02-2009, 16:46
Head Programmer
Heres an image
Unread 14-02-2009, 16:47
Derek,
Assuming you deleted the Button cluster indicator on the Joystick Get.vi, you can do one of a few things:
1. Use GetRaw.vi instead. The buttons behavior is identical to the Get.vi.
2. Copy the Buttons cluster from the GetRaw.vi and paste it onto the Get.vi.
a. you will then need to wire the buttons terminal to the original source.
b. you will also have to connect the buttons to the connector pane (right click the icon, select Show Connector, click on empty connector, then click on Buttons indicator.
3. Copy the Get.vi from another computer that has the WPI Robotics Library installed. The Get.vi is typically located at:
C:\Program Files\National Instruments\LabVIEW 8.5\vi.lib\Robotics Library\WPI\Joystick\Get.vi
-Nate
Unread 14-02-2009, 17:03
Head Programmer
My getraw.vi has the same problem :'(
Unread 14-02-2009, 17:09
Here is my Joystick Get.vi. Try that.
Unread 14-02-2009, 17:14
Head Programmer
lol thats the getaxis.vi
Unread 14-02-2009, 17:20
Sorry! :-) Here's take two.
Unread 14-02-2009, 17:41
Head Programmer
The one you gave me has the exact same problem mine does.
Can you show us picture of yours so I can try to fix it myself?
Unread 14-02-2009, 17:48
Perhaps what you did is you deleted the buttons out of the cluster itself. Try replacing this one (don't forget to unzip it first and back up your copy before replacing it).
C:\Program Files\National Instruments\LabVIEW 8.5\vi.lib\Robotics Library\WPI\Joystick\ButtonState.ctl
Did you want a picture of the front panel, or the block diagram?
Unread 14-02-2009, 17:56
Head Programmer
That worked! Thanks a lot
cad library Adama Inventor 6 17-01-2008 17:24
content library.. naroarr Inventor 0 20-01-2007 12:13
Library timers Ryan M. Programming 3 13-02-2004 09:02
Inventor Library Ogro Inventor 4 28-01-2004 17:03
Broken promises or BROKEN ROBOTS! archiver 1999 9 23-06-2002 22:18
