Go to Post Fun is not where you find it but where you make it. - Foster [more]
Unread 13-02-2009, 13:45
programmr's Avatar
programmr programmr is offline
AKA: Face
FRC #0522
programmr is a jewel in the roughprogrammr is a jewel in the roughprogrammr is a jewel in the rough
Send a message via AIM to programmr
Using Integer variables
Can anyone show me an example of how to setup an integer variable in the BuiltinDefaultCode example?
"I would love to change the world but no one will give me the source code"
Unread 13-02-2009, 13:55
Re: Using Integer variables
In general, it's as easy as saying
int varname;
replacing varname with the name you want to use. The proper place to put that line depends on what you want to use the variable for.
What do you want to use the variable for?
Unread 14-02-2009, 13:07
programmr's Avatar
AKA: Face
FRC #0522
yes, where to put the variable seems to be our problem. we want to use the variable to keep track of the state of one of our joystick buttons in teleop mode.
int x;
//Now later in the program during teleop routines
if (rightStick->GetRawButton(2)) {
if x = 1 {
x=0; }
else {
x=1; }
x could then be examined to determine the speed of our motors.
Unread 14-02-2009, 17:00
Sentient's Avatar
Sentient Sentient is offline
FRC #0639 (Code Red)
Sentient is on a distinguished road
Where to put x is called scope. If you want x available throughout teleop mode (but you don't need it anywhere else), you can put it directly after OperatorControl(){
You may want to do some more research into scope though. It is an important concept to master.
Unread 14-02-2009, 17:26
Rick Wagner's Avatar
Rick Wagner Rick Wagner is offline
FRC #3008 (Kalani Robotics)
Rick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to behold
int x;
if x = 1 {
x=0; }
else {
x=1; }
I think you want to be saying
if (x == 1) { ...
rather than the single equal sign, which is an assignment operator, not a conditional.
Displaying a 16 bit integer on PIC 16F877? Ian Curtis Programming 4 20-06-2008 15:42
integer print not making any sense. windell747 Programming 2 14-02-2008 23:32
integer division ImmortalAres Programming 5 11-07-2005 21:19
Integer Number powercat Programming 2 18-02-2003 11:26
