Go to Post This is about more than building a robot, we cannot only do the fun things. If you are fully involved than you will be prepared to do anything in life. - Andy Brockway [more]
Unread 14-02-2009, 14:35
agough's Avatar
agough agough is offline
FRC #0234 (Cyber Blue)
agough is an unknown quantity at this point
Question driverstation outputs
I think there is a way to output a line of code to the driverstation, does anyone know if it is possible? And if so then how?
"By failing to prepare, you are preparing to fail."-Benjamin Franklin
"Wise men talk because they have something to say; fools, because they have to say something."-Plato
Unread 14-02-2009, 17:38
alextm alextm is offline
FRC #0675
alextm is an unknown quantity at this point
Re: driverstation outputs
try reading this page: http://thinktank.wpi.edu/article/144
We have been having trouble though
Our bot says "No Code" if we try to use it
Unread 14-02-2009, 23:55
wt200999's Avatar
wt200999 wt200999 is offline
Texas Instruments
AKA: Will Toth
FRC #3005 (Robochargers)
wt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud of
Send a message via MSN to wt200999
Make sure you download the example that is on the right side of the screen, it has DriverStationLCD.h/cpp
Programming in LabVIEW? Try VI Snippets!
FIRST LEGO League 2004 - 2005
FRC Team 870 Student 2006 - 2009
FRC Team 3005 Mentor 2013 -
Unread 15-02-2009, 22:25
FRC #0675
we had incorrectly copied the code, but we got it working
question regarding driverstation ringo115 Programming 4 16-02-2009 11:16
Wiring LED to Driverstation sircedric4 Electrical 11 23-01-2009 08:31
Writing to DriverStation cRio screen alexjplant NI LabVIEW 2 17-01-2009 10:59
Relay outputs on rc jdawson Electrical 4 26-01-2003 12:51
Relay Outputs OddOne Technical Discussion 3 01-02-2002 19:52
