Go to Post Finally!!! I love hugs. - Eugenia Gabrielov [more]
Unread 14-02-2009, 18:33
Robostang 548's Avatar
Robostang 548 Robostang 548 is offline
I can program the future...
AKA: Don
FRC #0548 (Robostangs)
Robostang 548 is on a distinguished road
Send a message via AIM to Robostang 548 Send a message via MSN to Robostang 548 Send a message via Yahoo to Robostang 548
Victor=Fail on second digital sidecar
I know there have been posts about this already, but I wanted to talk about more than just the victor issue. Has anyone noticed that once you start using 2 digital sidecars all the rules just seem to go out the window? I noted this twice today.
Victors: Today was our first time using victors in labview. We have enough jaguars for everything but decided to use victors for our ball intake cause we don't need that much control and need to save weight and space. We setup the victor on the second digital sidecar(slot 6) and selected "victor" on the open motor block. When we ran the program the motor gave a sudden jolt then died. Restarting the program gave the same result. We changed it to a jaguar(both electrically and in the open motor block) and it worked flawlessly. We then tried setting up a victor on the first digital sidecar(slot 4) and it ran no problem. Note that the above experiments took place in a fresh robot project and there were no other motors declared.
Encoders: In our main code we already have 4 encoders running on our wheel's using sidecar 1 without issue. Upon trying to use an encoder on the second sidecar, we ran into trouble. We opened a fresh robot project only to find that the encoder would only count when the robot was disabled and not when enabled. Changing over to sidecar 1 made it run just like the other four in our actual robot code. Once again, all testing was done in a freshly made robot project with no other encoders declared.
Is there any explanation for this behavior? I know its just a matter of re-arranging our IO (because jaguars and servos still run fine on the second sidecar) but I still would like to know why this is happening. Our whole season has been like this with labview. A problem arises without reason, rectifies itself before it can be explained, and leaves us wondering if it will come back again.
Team 548:
Attending National Championship, Genesee District, Detroit District 2, West Michigan District, Michigan Championship?
Digital Sidecar problem Booksy FRC Control System 6 14-06-2009 05:31
No RSL on Digital Sidecar shobuda999 FRC Control System 16 08-02-2009 14:28
Digital Sidecar Problems cabbagekid2 FRC Control System 13 31-01-2009 17:23
Digital Sidecar Resistor NinJA999 Electrical 5 30-01-2009 19:53
What could cause a Victor to fail? bizarospooky Electrical 10 06-02-2008 09:35
