Go to Post Trust your data! - eugenebrooks [more]
Unread 14-02-2009, 18:44
bsiepser bsiepser is offline
FRC #1759
bsiepser is an unknown quantity at this point
Vertical Pool Noodle for Corners
Rather than making our pool noodles extend into the corners we were going to use vertical pool noodles to fill the corner gap. Does anyone have experience in fastening these to the robot or have any suggestions?
Unread 14-02-2009, 19:37
Kims Robot's Avatar Unsung FIRST Hero
Kims Robot Kims Robot is offline
Onto a New Chapter...
AKA: Kim O'Toole Eckhardt
Kims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond repute
Send a message via AIM to Kims Robot
Re: Vertical Pool Noodle for Corners
We did this one year, I think, and they just used hot glue to hold the pool noodle on. If you do a good enough job wrapping the bumpers, that should be all you need.
~kim~
Kimberly O'Toole Eckhardt <3
Principal Systems Engineer & Program Manager
History - Team 176, Team 229, Team 1511, FIRST Volunteer!!
My new FIRST Photography Hobby & Angry Eric's Fan Page
Excellence - is the result of caring more than others think is wise, risking more than others think is safe, dreaming more than others think is practical, and expecting more than others think is possible.
Unread 14-02-2009, 20:17
hipsterjr's Avatar
hipsterjr hipsterjr is offline
Your bot can score but can it dance
AKA: CJ
FRC #4451 (The Burning Magnetos)
hipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond repute
Send a message via AIM to hipsterjr
I hope so, because that is what I did Yesterday. can we get a rule quote?
2010 Palmetto Chairmens Winner
2009 Peachtree Finalist Thanks 1319 & 590 "Sure your robot can score, but can it dance?!"
2008 Palmetto Regional Finalist Thanks 343 & 804
2008 Florida Regional Finalist Thanks 179 & 69
2007 Palmetto Regional winners Thanks 1319 & 832
2005 Palmetto Chairmens Winner
Unread 15-02-2009, 07:37
GaryVoshol's Avatar
Cogito ergo arbitro
<R08> is your friend ... or maybe not
(since 2004)
Unread 15-02-2009, 16:23
FRC #1759
I'm thinking sewing the vertical noodle to one of the other bumpers? Then there's definitely nothing "hard" outside of the plywood and bolts. I should probably put this on the Q&A or maybe just ask an inspector day of.
Unread 15-02-2009, 16:50
GaryVoshol's Avatar
Cogito ergo arbitro
You put the vertical noodle portion inside the fabric of the adjacent bumper segment. The vertical noodle is not a separate piece of bumper.
To me, it would be easier to cut the pool noodles about 3.5 inches long and have the pair of noodles extend past the end of the plywood, rather than fiddle with an extra piece of vertical noodle. In the past the vertical noodle was the only method allowed of extending into the corners. This year we have several options.
(since 2004)
Unread 18-02-2009, 08:29
Although there doesn't seem to be anything preventing the extension of the horizontal noodles into the corners, it has been my experience that the vertical pool noodle seems to add a bit more protection. You can use hot glue but the surface at the glue point is pretty small. If you use the specified heavy fabric, the vertical piece is held firmly in place and looks pretty nice. For your own piece of mind, please follow
"D. The BUMPERS must be covered with a rugged, smooth cloth (1000 dernier Cordura Plus® strongly recommended). The cloth must cover all external parts of the bumper material (pool noodle) and backing (plywood)." Results will vary but this will prevent an issue if your bumper falls apart during a match due to weak fabric covering.
Unread 18-02-2009, 09:51
chinckley chinckley is offline
Winner 2009 West Michigan District
FRC #1254 (Entropy)
chinckley is a name known to allchinckley is a name known to allchinckley is a name known to allchinckley is a name known to allchinckley is a name known to allchinckley is a name known to all
We use the 1000 Cordura and have never had an issue with the material.
the vertical piece of noodle holds up well in there too and there is not any slipage from side to side.
Works great for us.
2009 West Michigan District Winner
Thanks to Team 216 and Team 1918
2009 Traverse City Semifinalist
Thanks to Team 1596 and Team 47
2009 Traverse City UL Safety Award Winners
Attending 2009: West Michigan, Traverse City, & State
Unread 24-02-2009, 13:37
Zflash's Avatar
Zflash Zflash is offline
AKA: Erich Zende
FRC #1319 (Flash)
Zflash has much to be proud ofZflash has much to be proud ofZflash has much to be proud ofZflash has much to be proud ofZflash has much to be proud ofZflash has much to be proud ofZflash has much to be proud ofZflash has much to be proud ofZflash has much to be proud ofZflash has much to be proud of
Does the pool noodle need to extend over the corner if there are bumpers on each side of the corner? Sorry for the Example below
______
__|______
| |Robot
| | Frame here
Peachtree '08 Champion Thanks 343 & 547
Galileo '07 Champion Thanks 173 & 1902
Palmetto '07 Champion Thanks 832 & 342
Boilermaker '06 Champion Thanks 1272 & 85
Unread 24-02-2009, 13:51
in between teams
AKA: Luke Van Oort
Yes, corners must be protected and there must be >=6" of bumpers on each side of the corner (not including the pool noodle in the corner).
Team 1219: 2009 - Mentor
Unread 24-02-2009, 14:15
Zflash's Avatar
AKA: Erich Zende
FRC #1319 (Flash)
http://www.chiefdelphi.com/media/photos/33101?
Not to pick on them it was the closest robot I could find. What you are describing is that thier bumpers and any like it are illegal. Correct?
Unread 24-02-2009, 14:17
in between teams
AKA: Luke Van Oort
As pictured, yes (that pic is kinda blurry so it's hard to tell for sure).
Unread 24-02-2009, 14:32
Please see figure 2 in the Rev J version of the Robot Rules Section 8. I cannot see the corner very well in the picture you linked but if it looks like the right side of figure 2 then the answer is "no".
J. Corners and joints between BUMPER segments may be filled with short pieces of vertically
oriented pool noodle, by wrapping the pool noodles around the corners, or by beveling the
ends between adjacent segments so they form a tight and complete protective surface (see
Figure 8 – 2).
and
N. BUMPERS may extend beyond the BUMPER PERIMETER by up to a maximum of 3-1/2
inches per side. “Hard” parts of the BUMPER (i.e. plywood backing, fastening system, and
clamping angles) may extend up to a maximum of one inch beyond the BUMPER
PERIMETER. Only “soft” parts of the BUMPERS (i.e. pool noodles and cloth covering) may
extend more than one inch beyond the BUMPER PERIMETER.
Source for pool noodles Bruceb General Forum 9 04-01-2009 18:35
How to filter the corners in image to get mouth corners only? tommy_chai Programming 3 20-11-2007 13:22
Bumper Question - More like Pool Noodle bLuEpHoEnIx Technical Discussion 5 12-02-2007 21:33
noodle bumper munch General Forum 2 09-02-2006 17:25
Anyone from the four corners region? ZuniHigh Regional Competitions 0 15-01-2004 20:07
