Go to Post Don’t choose to aim for the stars because they mark the peak of our abilities, don’t choose to aim for the stars because it is easy, choose to aim for the stars because it shows the depth of our potential; choose to aim for the stars because it is hard! - Ken Leung [more]
Unread 14-02-2009, 19:01
iSnoopy iSnoopy is offline
AKA: Alec
FRC #2554 (WarHawks)
Team Role: Electrical
iSnoopy is an unknown quantity at this point
Micro Switch + PWM = Button?
I have put together a "joystick" or a "button" by soldering a PWM to a micro switch(from the KOP). However, we cannot get the robot to read the button input. We do not believe the code is wrong (It might be wrong) and I'm wondering if its just the way the micro switch is connected to the Driver Station. I did a continuity test and it does have current flowing through it when the switch (button) is pressed. Is it possible to use the micro switch as a button for shooting? Is using a PWM the problem? Please reply ASAP
Micro Switch Code dboisvert C/C++ 2 13-02-2009 13:34
button Switch GunfighterJ Programming 10 10-02-2009 19:39
using a switch/button to turn on a motor smcmahon NI LabVIEW 3 26-01-2009 18:42
push-button switch on robot Conan Electrical 4 10-02-2006 22:03
Need Help Wiring Micro Switch/Limiting Switch Windward Electrical 2 07-02-2006 18:26
