Go to Post what hint? - Electricia 1599 [more]
Unread 14-02-2009, 19:26
Re: Change two color tracking vi from tracking pink AND green to orange OR grape ball
There is also a LV example for finding a single color object. To update it to find a second color, you have two choices -- prioritize one and do the second only if you don't find the first, or search for them in parallel and take the biggest/best one you find. The first version will duplicate some of the code, put it in a case, and only execute it if you don't find a good first target. The second approach will search for both, compare the results, and then decide on the outcome.
Greg McKaskle
two color tracking code Team2883 Programming 16 09-02-2009 00:21
Multiple Targets in "LabVIEW Sample two-color target tracking code" markulrich NI LabVIEW 7 29-01-2009 11:52
Two Color Tracking Demo Bharat Nain Programming 43 25-01-2009 18:58
Issue with Color Tracking Example (C/C++) and with Counters, Encoders, and Ultrasonic BradAMiller Programming 3 19-01-2009 21:24
Two color tracking problem nadavsen2 Programming 3 19-01-2009 14:44
