Go to Post its not that I cant spell, I'm just being international. . . . I like it - Stuart [more]
Unread 14-02-2009, 20:42
professorX professorX is offline
AKA: Xavier
FRC #1660 (The Harlem Knights)
professorX is an unknown quantity at this point
Re: Solenoid Not Working
Is the solenoid a 24V one, by any chance? The ones in the KOP in past years had a particular mod to get them to work with 12V. Classic symptom was the manual firing worked and the electronic didn't.
Is there any way to get them to work electrically?
Unread 14-02-2009, 20:49
Yes. However, I don't know exactly what it is. I'll let the folks who actually do that sort of thing explain how. (It may also be in an old FRC pneumatics manual.)
It would also kind of depend on the solenoid.
Unread 14-02-2009, 21:32
AKA: Xavier
It is the SMC’s double solenoid valve.
I connected the two red wires to the M+ and M- on the spike and the two black wires are connected to the Power Distribution Block both conducting negative charge.
Unread 14-02-2009, 21:56
Oh, that one. Yeah, that comes in the older KOPs as a 24V, with the conversion stuff. Problem is, I don't know how to do it. I think it has something to do with a small gray clip or something, but I really don't know. Could someone who's done that conversion weigh in here?
Unread 15-02-2009, 07:48
AKA: Xavier
EricH, thank you for your help so far.
I'm still trying to figure out how to make it work electrically.
My team might end up using the festo single solenoid but I'm not sure how it suppose to wire to the the pneumatic bumber on slot 8. And also, would it work if I connected the festo solenoid to a relay?
Unread 15-02-2009, 23:20
AKA: Xavier
We finally got the SMC solenoid valve to work.
The problem was that both of the solenoid that we used were not functional.
Thank you EricH for you help.
Remembering not working EricH CD Forum Support 9 21-07-2008 07:43
p2 not working? Lone_Wolf92c Programming 5 22-02-2008 08:49
IR Board Not Working (But NOT Fried) itsme Electrical 2 18-02-2008 06:11
Camera not working st1nkm4n Programming 7 02-02-2006 08:22
Radios not working... E Jones 234 Electrical 3 21-01-2005 21:58
