Go to Post Do what you want. Deal with the results. - Andy Baker [more]
Unread 14-02-2009, 21:04
JimC2550 JimC2550 is offline
FRC #2550
JimC2550 is an unknown quantity at this point
Basic Robot Framework
Does anyone know if we are limited to use slot 4 for the digital side car?
Our slot 4 has a problem.
We can make motors run with PWM from slot 6.
but the Basic Robot Project framework seems to have issues.
I think we can parallel the controls that the framwork channels to slot 4 and use slot 6. so if we do this, will the FRC Management system allow us to compete?
Ideas?
JimC2550
Unread 14-02-2009, 21:09
360skier 360skier is offline
RTFM!!
AKA: Eric A.
FRC #1334 (Red Devils)
360skier is an unknown quantity at this point
Re: Basic Robot Framework
If you use a different slot than the default one, your programmers will need to compensate for that in their code. Also, The RSL indicator that gets plugged into the Digital Sidecar might not work for a different slot. If this is the case, you might need to have two digital sidecars (one for RSL and one for everything else).
Camera on basic framework Arcre NI LabVIEW 2 11-02-2009 04:17
New TipJar Training Video - Making Friends with the FRC Advanced Robot Framework LVMastery Programming 0 05-01-2009 14:54
Robot Framework lord Purity Pneumatics 3 21-01-2007 15:57
Basic Robot Layout gsorozco Technical Discussion 8 12-02-2006 19:15
Basic Robot Layout gsorozco Website Design/Showcase 0 30-01-2006 02:13
