Go to Post Enlighten a man who sometimes has difficulty understanding why others stray outside the box, when the box appears to be an optimized and elegant solution. - JVN [more]
Unread 14-02-2009, 21:57
Pausert Pausert is offline
FRC #1727 (REX)
Pausert is an unknown quantity at this point
Re: adding a second joystick to TeleOp Init
Sorry to double post, but I though that this may make it easier to see:
This is does exactly the same thing as the posted code, but uses the basic structure rather than the advanced structure. There is a 2 wired to the second "OpenJoysick.vi" because I was messing around and hoped that it might fix it.
Adding all devices to Typedef increases Teleop by 100 ms per iteration rwood359 NI LabVIEW 1 07-02-2009 22:11
adding second camera iwdu15 Electrical 1 01-02-2007 20:53
Wierd basic init Jeremy J Programming 5 06-02-2003 11:42
Basic Init Error yan184 Programming 5 14-12-2002 13:10
Programming the second joystick in PBASIC archiver 2001 2 24-06-2002 00:25
