Go to Post You can have any color robot you like, so long as it stays that color. So you shouldn't have to worry unless you have a chameleon bot. - Kevin Sevcik [more]
Unread 14-02-2009, 23:53
Mentor_Mike Mentor_Mike is offline
Mentor/Student/Wishful Thinker
FRC #2809 (K-Botics)
Mentor_Mike will become famous soon enoughMentor_Mike will become famous soon enough
Re: 2809 - Traction Control Demo
Originally Posted by Mr.G View Post
We are using a torque sensor on each wheel. You can only apply so much torque to a wheel before it slips. Since everything is constant (robot weight, playing surface, wheel, ...) then all you have to do is apply power to the wheel till you reach a predetermined torque target and the wheel will not slip and you will approach max acceleration and pushing power.
I don't know if this is how you are doing it, I am guessing, but that is what we are doing.
Torque sensor eh? For curiousity sake, how do those work in your system?
Mentor (2008-present)
610:
Mentor (2005-2007)
Team Leader - Driver (2004-2005)
Operator (2004)
Non-Mechanical Head (2003-2004)
Code/Grease-monkey (2001-2003)
Team 121 Traction Control Tom Schindler Robot Showcase 66 12-02-2009 22:53
Implementation of Traction Control keehun Programming 5 10-02-2009 10:02
PID traction Control dpeterson3 C/C++ 5 26-01-2009 21:11
Is it worth it to implement traction control? dmlawrence Rules/Strategy 5 05-01-2009 21:28
Traction Control Algorithm Mr. Lim Programming 3 20-01-2004 14:26
