Go to Post Ok, I am geting flustered since I can't perform trigonometric functions with the tools FIRST provides. - jweric [more]
Unread 14-02-2009, 14:35
GillSt.Bernards's Avatar
GillSt.Bernards GillSt.Bernards is offline
AKA: Amanda Cullen
FRC #2458 (Team Chaos)
GillSt.Bernards is a name known to allGillSt.Bernards is a name known to allGillSt.Bernards is a name known to allGillSt.Bernards is a name known to allGillSt.Bernards is a name known to allGillSt.Bernards is a name known to all
Send a message via AIM to GillSt.Bernards
Question Crio Help
Our problem is that we are trying to connect to the CRIO and even though it says that it is connected we cannot detect it from the computer nor the drivers station. We have tried directly connecting it with ethernet bridges but that is not making a difference. Ever since we downloaded the new version of the drivers station it is not working and it was working before. The status light is off. Any advice.
P.S.: we have had this problem before but it worked itself out. This time it is not doing that.
"A Dream is just a dream, a goal is a plan with a deadline" - Fortune Cookie-
"Life is a runaway train you can't wait to jump on"
-Sugarland (Already Gone)-
Unread 15-02-2009, 00:00
Re: Crio Help
You updated the Driver Station firmware. Did you also update the cRIO? The light should only be off while the cRIO is either off or in the early stages of booting up, or if it's still running the original "OTB" code.
Need help with CRIO GillSt.Bernards Electrical 4 14-02-2009 14:42
CRIO HELP!!! lordsoze Technical Discussion 8 07-02-2009 08:48
Dead cRIO??!!? HELP!!! naruto137 Technical Discussion 11 05-02-2009 23:58
cRio IP change help mastergamer1231 Programming 1 03-02-2009 19:38
Help Getting cRIO Feedback rholokleolke C/C++ 3 29-01-2009 17:13
